Electric water pump conversion
Old May 7, 2009 | 12:48 AM
dbilik's Avatar
dbilik
Default Electric water pump conversion
I know this is slightly different than an actual electric water pump as it utilizes the existing water pump. Anyone used one? Anyone seen one?
http://www.jcwhitney.com/Water-Pumps...1656_10101.jcw
Old May 7, 2009 | 01:57 AM
Crazy4x4RT's Avatar
Crazy4x4RT
I've seen adds for it. It's cool if there are no other options. Like said before the correct one is in the FAQ2.
http://www.csr-performance.com/csr_pumps.html
Old May 8, 2009 | 12:18 AM
1shotjake's Avatar
1shotjake
I don't know if you saw this in the other thread, but here's the direct fit CSR pump on summit
http://store.summitracing.com/partde...5&autoview=sku
Old May 8, 2009 | 01:18 AM
dbilik's Avatar
dbilik
Yeah, I saw it after I had posted this. CSR is definately a better product I can tell.
Old May 8, 2009 | 01:59 AM
Hahns5.2's Avatar
Hahns5.2
Where do you think the power is coming from to power the electric waterpump?
Hint: It's not coming out of thin air...
Old May 8, 2009 | 02:17 AM
95_318SLT's Avatar
95_318SLT
It comes from the alt, which the engine has to turn, sure, but they wouldn't make them if they weren't more efficient. Take an electric radiator fan for instance... the mechanical fan has been dyno proven to rob 15 hp when the clutch is engaged. A typical electric fan that draws 20 amps at 14.4 volts only robs 0.38 hp. Yes, it takes electricity to run these things, but they are more efficient, so it takes less power from the motor than their mechanical counterparts.
Old May 8, 2009 | 02:24 AM
dodgerules86's Avatar
dodgerules86
True that!
My Corolla has electric power steering. (No pump, no fluid) They said they went with this for gas savings. A lot of people aren't big fans. It seems harder to keep center, and just feels different. (I wonder about reliability...)
I've seen the electric water pumps. It came, and went, thru my head. I still think their a neat idea.
Old May 8, 2009 | 03:59 AM
Hahns5.2's Avatar
Hahns5.2
Electric fans biggest benefit is when it's completely off, the power saving when it's on can be attributed to less rotating mass, less CFM and more efficient blade design.
The electric water pump still has to move at least as much water as the stock pump, which requires the same amount of power because it has to do just as much work. I still fail to see how an electric water pump will gain you any HP.
Old May 8, 2009 | 04:13 AM
dane25's Avatar
dane25
that's nice....
Old May 8, 2009 | 11:53 AM
RockGuardedDak's Avatar
RockGuardedDak
those look like a good idea, however, my question is, does the stock drive belt still get used? if so, then how does it run past the water pump?
