code 15 help?!?!
Old Oct 25, 2009 | 09:47 PM
4x4Dakota93's Avatar
4x4Dakota93
Default code 15 help?!?!
its means vehicle speed sensor is bad...
i replaced the sensor and im still getting the code...
and my tach, sped and odometer still dont work...
could it be a ground or does anybody else have any ideas??
Old Oct 25, 2009 | 09:58 PM
95_318SLT's Avatar
95_318SLT
I'd start with the fuses. Anytime any electrical problem occurs, I go straight to the fuse box. If they all check out, it could be a ground issue. We have the '95 FSM available for free download in faq2 (its a rapidshare link). That will be very close to the same thing as your '93, except your '93 should have a cable drive speedometer and seperate electric speed sensor for the computer and the '95s have an all electronic speed sensor (no cable). Anyway, it will have wire diagrams to track down the potential ground problem.
Old Oct 25, 2009 | 10:12 PM
4x4Dakota93
i think it said left side fender shield if i downloaded the right file but im not sure what that means =(
Old Oct 25, 2009 | 10:26 PM
95_318SLT's Avatar
95_318SLT
Thats what I read too. The ground is on the left fender shield. That would refer to the removable inner fender well. The power distribution sensor is directly above the left inner fender well. Check all the grounds around there if the fuses look good.
Old Oct 25, 2009 | 10:31 PM
95_318SLT's Avatar
95_318SLT
No, on second thought, thats not it. It says "Vehicle will not start if the vehicle looses this ground."
Read page 8W-30-3 and 8W-30-26 for better info.
**EDIT**
Check pins 47, 7, and 4 on the PCM and make sure there is a clean connection. Also, if you have a multimeter, make sure pin 7 is putting out 8 volts.
Old Oct 25, 2009 | 10:53 PM
4x4Dakota93
by right fender side PCM....
do they mean passenger or driver side?
the PCM looks like what? black long rectangular box? bout 6 inchs long by 1 and 1/2 wide? or is that something else?
Old Oct 25, 2009 | 11:07 PM
Crazy4x4RT's Avatar
Crazy4x4RT
When talking about right or left side you always take it as you are in the drivers seat. So right is passenger side. Here is what it looks like.
Old Oct 25, 2009 | 11:10 PM
4x4Dakota93
ok i found the pcm =) now i need to find a pcm pin diagram?
Old Oct 25, 2009 | 11:12 PM
95_318SLT's Avatar
95_318SLT
There is a diagram on page 8W-80-11
Old Oct 25, 2009 | 11:23 PM
4x4Dakota93
thx, found diagram and no multimeter, pins look clean tho
i do have a jet chip install right here by the way, not sure if thats messing anything up
