Both high beams and low beams?
Old May 28, 2010 | 05:50 PM
oxygen454's Avatar
oxygen454
Lightbulb Both high beams and low beams?
Have you guys ever modded your lights so the low beams stay on when the high beams are on? Most likely using a relay and maybe a diode?
Old May 28, 2010 | 09:42 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Why? Are you trying to get them brighter? My thoughts are that it will burn up the bulb to quick, and not get brighter, or at lest enough.
But yes a relay and some thick enough wires will do.
Old May 28, 2010 | 10:28 PM
Dodge4lyfe's Avatar
Dodge4lyfe
If you want brighter lights either add more lights or get some overwatt bulbs. I remember seeing on here a thing about lights and testing diferent bulbs, and which ones are best.
Old May 28, 2010 | 10:46 PM
dhvaughan's Avatar
dhvaughan
i have. i didn't want to melt down my truck, so i bought the Brite-Box for about $100. installs in about 10 minutes.
http://www.dieselsite.com/index.asp?...ROD&ProdID=357
Old May 29, 2010 | 12:03 AM
oxygen454's Avatar
oxygen454
I noticed the other night that when I held the high beam toggle switch, the lows stayed on. I like the added coverage of the lights with out adding more lights to my truck.
Eventually I plan on making a custom bumper for the truck which I have a design made up for but not any time soon. (with lights in the bumper)
So I think I will add the relay so the power from the high beams trigger the relay to turn the low beams back on. The amperage and voltage will not be any higher to the bulbs than when they are on separate modes so they should not have a shortened life.
Old May 29, 2010 | 03:39 AM
festerw's Avatar
festerw
The load will be the same yes, but the heat generated will be more than on a single mode which is what will shorten the bulb life.
Old May 30, 2010 | 01:50 AM
oxygen454's Avatar
oxygen454
The headlight is a one bulb unit? Never thought about that. I would only use it a max of 5 minutes down a long dark road on the way home from work. (driving at about 90km/h). Might hold off till I get my bumper built with lights in it.
Thanks
Old May 30, 2010 | 03:20 AM
Auron's Avatar
Auron
i forgot your from kanadia for a minute there
Old May 30, 2010 | 05:36 PM
oxygen454's Avatar
oxygen454
haha and your an Americana Yankee-doodle LOL . Meh its all good eh? We are in km and you guys are in miles. Funny thing is, we use metric when driving but in the trades, there is almost more use in standard (inches/feet) than metric. Go figure.
Old May 30, 2010 | 10:36 PM
Auron's Avatar
Auron
lol my great uncle has a house on 5 island lake on the maine canada border but he is in canada but get a set of $30 walmart aux lights and stash them behind the grill and you will be golden
