Paint Problems
Old Jun 26, 2010 | 01:14 PM
dobaroy's Avatar
dobaroy
Default Paint Problems
Looking at buying a '92 Dak with around 90,000 miles on it. It has a 5.2 and the biggest problem seems to be the paint. It is grey and white with a red stripe on it. The paint has peeled real bad and wondering if we were to repaint it, what should we be thinking of doing. Any help would be appreciated. Thanks, Roy
Old Jun 26, 2010 | 02:37 PM
Crazy4x4RT's Avatar
Crazy4x4RT
1. Tons of sanding! And more sanding! And more sanding!!
Or
1. Chemical paint remover. Then sanding and More sanding!
2. Fix dents, rust, line up body panels, get gaps consistent.
3. Bondo the areas that need it. Don't go over 1/4in thick.
4. More sanding.
5. Primer
6. More sanding.
7. Paint
8. 2nd or 3rd coat of paint.
9. More sanding if needed.
10. Clear coat.
11. 2nd clear coat.
More or less in these steps. Have fun!!!!
Old Jun 26, 2010 | 07:24 PM
Bkilla's Avatar
Bkilla
Yep all of that and some more sanding. Just to give you an Idea of cost I just started work on a buddies '99 Dakota. A. he is getting a hell of a deal from me on labor, but befor buying the actual top coat of paint the bill for materials was about $430.00 that was sand paper, primer, wax and grease remover, some tack cloths, medium weight body filler, light weight body filler, reducer, catalyst, body filler spreaders, mixing cups...and some other things.
Old Jun 26, 2010 | 10:04 PM
dobaroy's Avatar
dobaroy
Thanks for the replies. Does anybody know what caused the paint on these trucks to peel like that? Was it Chrysler paint gone wrong? And yeah, I get the message about the sanding (loud and clear). Maybe paint remover will be on my list.
Old Jun 26, 2010 | 10:13 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I don't know for sure why the paint is peeling on yours. But some times if the primer and paint and not compatible the paint will do that. If the clear is peeling it is the paint and clear coat were not compatible.
Other elements too like the Sun or Salt will make the deterioration happen a lot faster.
Old Jun 26, 2010 | 11:10 PM
luthoro's Avatar
luthoro
Mine is the same paint scheme, and mine is also very faded.
Old Jun 27, 2010 | 12:21 AM
Dodge4lyfe's Avatar
Dodge4lyfe
from 1986 until about 1995-96 Chrysler had issues with paint peeling on vehicles, especially lighter colored ones(silver, gray, etc.) This was due to a bad batch of primer that Chrysler had recieved and didn't start seeing the peeling issue until the 90's. My '92 Dak that I had in high school was duct tape silver and when I bought it it had about half the paint peeled until the dodge dealer took it through the car wash and then all the rest of it came off...
Old Jun 27, 2010 | 02:53 AM
Deerkiller9991's Avatar
Deerkiller9991
99 cent walmart spray paint lol...wish i had time/money to paint mine....cant even afford wally world paint
Old Jun 27, 2010 | 07:27 AM
95_318SLT's Avatar
95_318SLT
I could never bring myself to spray can a car. I worked over 3 years in a body shop, so I learned how to do all this stuff the right way. I sprayed my truck 2 years ago with Du Pont base/clear and it still looks nicer than a lot of new cars' paint jobs when its clean.
Old Aug 20, 2010 | 03:27 PM
Sethinphx's Avatar
Sethinphx
I have a white 96 dakota and the paint is peeling like the skin off Micheal Jacksons face. I just deal. Its a work truck.
