timing chain on a 3.9L
Old 02-28-2011, 05:55 PM
thager's Avatar
thager
thager is offline
Default timing chain on a 3.9L
has anyone done a timing chain job on 3.9L? any tips or tricks i should know of?
Old 02-28-2011, 07:10 PM
daved's Avatar
daved
daved is offline
I know there are updated parts for it so I would make sure you get them.
Old 02-28-2011, 07:23 PM
kahanabob's Avatar
kahanabob
kahanabob is offline
just line the dots up on the old one before you remove it and then line the dots up on the new one.
Old 02-28-2011, 08:53 PM
siggie30's Avatar
siggie30
siggie30 is offline
Do not use the crank bolt to seat the balancer. Use lube in large amounts. Stop your engine at 0 degree's before starting. Buy all the gaskets and seals and fluids beforehand. Have a helper remove the old gear so you do not get dirty.
Old 03-01-2011, 01:24 AM
ddgdkt96's Avatar
ddgdkt96
ddgdkt96 is offline
Its pretty easy, just be prepared to drain your radiator, have a gear puller available and take your time, line up the marks, I think the Serv manual says to line up TDC for #2, but you will see the two dots, they will line up. do not turn the engine when everything is torn apart!!!
good luck, its not bad at all.
Timing Chain Checking and replacing
symptoms:
Rattling or lifter type noise coming from the front (chain case) area of the engine.
diagnosis:
Start the engine and bring it to operating temperature. Increase and decrease engine RPM slightly while listening to the front end of the engine for a rattling or lifter type noise. A stethoscope can be used to help pin point the noise location. If the noise is found coming from the timing chain case, perform the Repair Procedure.
parts:
  • 1 83507095 Timing Chain and Sprocket Package
  • 1 53021057 Gasket, Timing Chain Case
  • 1 04483757 Gasket, Water Pump 1992 - 1997
  • 1 4897297AA Seal, Front Case 1992 - 1997
  • 1 53021195AA Tensioner, Timing Chain
repair:
This bulletin involves replacing the timing chain and sprockets and installing a timing chain tensioner.
1. Following the appropriate service manual procedures, disassemble the front end of the engine to gain access to the timing chain and sprockets.
2. Remove the chain and sprockets from the engine. Discard the parts.
3. Remove the chain oil tab the parts. thrust plate and (Figure 1). Discard the parts.
4. Install the timing chain tensioner p/n 53021195AA in the position where the thrust plate and oil tab was installed (Figure 2). Torque the bolts to 24 Nm (21 0 in. Lbs.).
[IMG]file:///C:/Users/Patrick/AppData/Local/Temp/msohtmlclip1/02/clip_image001.jpg[/IMG]
[IMG]file:///C:/Users/Patrick/AppData/Local/Temp/msohtmlclip1/02/clip_image002.jpg[/IMG]
5. Install the new timing sprockets and chain pln 083507095. Align the timing marks per the appropriate service manual procedure. Torque the camshaft bolt to 68 Nm (50 ft. Lbs.).
6. Remove the lock pin that holds the tensioner plate for the chain. Discard the pin.
NOTE: WITH THE TIMING CHAIN TENSIONER INSTALLED, THE CAMSHAFT END PLAY WILL BE 0.051 - 0.330MM (.002 TO.013 IN).
7. Reinstall the remaining components per the appropriate service manual procedures.
notes:
POLICY: Reimbursable within the provisions of the warranty.
TIME ALLOWANCE:
Labor Operation No: 09-10-05-92 .................................. 2.3 Hrs.
Optional Equipment:
09-10-05-61 Power Steering ...................... 0.2 Hrs.
09-10-05-63 Air Conditioning ..................... 0.4 Hrs.
FAILURE CODE: P8 - New Part
Old 03-10-2011, 09:43 AM
thager's Avatar
thager
thager is offline
well i got my parts, so to get this job done.
the ****ty deal is , i have to work out side because the truck wont run so i cant get it in to my garage.
Old 03-10-2011, 10:36 AM
kahanabob's Avatar
kahanabob
you say the truck won't run, is it because of the timing chain? if so, if it is broke or sliped a tooth then the install of the new one just got more involved.
Old 03-10-2011, 11:07 AM
thager's Avatar
thager
thager is offline
it will run , but it backfires and when i put in gear and press the gas it dies, my father in law is a mechanic and the was here last week and checked it out.
the chain is streched and the timing is off thats why it wont run. the chain and gear set and the gasket set was $80 total.
Old 03-10-2011, 12:51 PM
Soundguy's Avatar
Soundguy
Soundguy is offline
$80? Where did you get it? Did the gaskets and seal come with the kit?
Old 03-10-2011, 07:38 PM
thager's Avatar
thager
thager is offline
i got a buddy at a parts store here, yes timing cover gasket,2 waterpump gaskets(1 for the v6 and 1 for v8) and the crank seal.
Quick Reply: timing chain on a 3.9L
