Gearshift linkage
Does anyone have any pictures of how the linkage rod is supposed to be connected between the throttle body and transmission? It's a '88 Dakota 3.9 4wd 3spd auto. It's been so long since I disassembled it, that I have forgotten how it was fitted(oops..). I have fitted the rod(?) on the throttle body and on the linkage on the transmission, but it's all loose and doesn't work like it should.
Thanks,
Ole
Thanks,
Ole
Bump!
This is the rod I'm talking about, at the throttle body end;
http://img.photobucket.com/albums/v4...-32-07_700.jpg
At the lower end, on the transmission;
http://img.photobucket.com/albums/v4...-30-45_665.jpg
Normally I would help but being a 88 there is noting I can help with. Hopefully someone can take some pictures for you. Possibly try your local junkyards to see if they have what you need. Or www.craigslist.org
![Frown](https://dodgeforum.com/forum/images/smilies/frown.gif)
I was hoping to get this solved, since the rest of the car is about to get done. It's got a
new engine rebuild, torque converter, tubular headers, HID headlights, taillights, keyless
entry system and half of the frame sandblasted and painted(rust, bleh).
If you haven't already try a www.google.com search. Search for "88 Dakota engine" under the Images tab.
