Weak Starter?
Old Aug 20, 2012 | 11:05 PM
pinkfloydeffect's Avatar
pinkfloydeffect
Lightbulb Weak Starter?
Ever since I've owned my 3.9L Dakota I have had to hold the starter for a few seconds to fire. But instead I usually give it a quick turn over, stop, then it always fires right up on the second quick turn over. I always thought of it as priming the engine on the first quick turn over (I don't like cranking-out my starter) I've heard other Dakotas fire in under a second right away, I only have 76K (1988) so I was thinking maybe my starter is getting weak? My dad replaced the starter in his Cherokee and he claims it starts faster now.
Old Aug 21, 2012 | 01:27 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Ya possibly a weak starter or your loosing your fuel pressure through out the night so it takes the pump a little bit to build it back up. Get a fuel pressure gauge and see if you loose your prime through out the night.
There is a check valve on the fuel pump but you will have to replace the entire sending unit. Best option is to add in an universal check valve, I did a write up on installing one its in the FAQ.
Old Aug 22, 2012 | 01:03 AM
pinkfloydeffect
I did the on/off thing 3 times then tried to start and I'll admit it cut the time in half but still a bit hesitant. Maybe that is as good as it gets, 6 months ago I put a brand new fuel pump in, brand new in line filter, new ignition coil, and a new pickup coil in the distributor. Even the gas lines were replaced a few years ago but not standard metal lines like the factory...my grandfather used flexible plastic oil line hose which supposedly exceeds the standards of gas line?
Old Aug 23, 2012 | 10:52 PM
marcar1993's Avatar
marcar1993
Try turning it to the on position and wait 2 seconds then start, that should prime the fuel rail all by itself and then it should start first crank.
Old Aug 23, 2012 | 10:59 PM
pinkfloydeffect
Does not help, also no fuel rail its TBI not EFI
Old Aug 24, 2012 | 05:45 AM
JR318's Avatar
JR318
Have you tested the battery to see if its dropping voltage when you turn it over? The battery voltage should not drop more than 2 volts when turning it over or putting the battery under a load. If it drops more then it could be an issue with the battery and not the starter. Just make sure to test that before you buy a starter.
Old Aug 24, 2012 | 11:36 AM
pinkfloydeffect
Can I watch my battery gauge on the dash or do I need to have someone manually use a tester while I crank?
Old Aug 24, 2012 | 06:20 PM
JR318's Avatar
JR318
Just use a digital meter and connect it to battery and sit it up where you can see it from inside truck.
Old Aug 27, 2012 | 09:35 PM
pinkfloydeffect
I checked, I get (roughly) 12.5 with ignition on, bottoms out to 10ish on the start and idles around 13.5 when running. I'm thinking the fuel pressure regulator
