help with new air filter
Old Dec 28, 2012 | 02:05 PM
jdosegueda's Avatar
jdosegueda
Default help with new air filter
have a 91 dakota v8 and want to know if i can put in a diffrent one that looks better than the stock one
Old Dec 28, 2012 | 06:16 PM
melodytoinvent's Avatar
melodytoinvent
You mean just the filter itself or like a new kit with filter and housing? Either way, yes lol.
Old Dec 28, 2012 | 11:04 PM
jdosegueda's Avatar
jdosegueda
yea like th neww kit and housing my bad and where could i get it aha
Old Dec 28, 2012 | 11:10 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Lots of places. www.summitracing.com www.jegs.com www.ebay.com
Here is my K&N air filter system with the X-Stream filter top.
Old Dec 28, 2012 | 11:58 PM
jdosegueda's Avatar
jdosegueda
will http://www.summitracing.com/parts/kn...kota/year/1992 work because i cant find one for a 91 v8
Old Dec 29, 2012 | 09:50 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Originally Posted by jdosegueda
hey
i was wondering where you got your air filter system i cant seem to find one for a 91 only for 91 but would a 92 fit on my 91 dakota?
From Summit.
I don't know if it will work on a 91, I got a 93. Post up pictures of your stock air filer and with it removed.
Old Dec 31, 2012 | 03:15 PM
wyrmrider's Avatar
wyrmrider
I have a chevy truck housing and filter
higher but still fits and larger diamater
do hook up to cold air
Old Jan 3, 2013 | 11:24 AM
Idmtboy's Avatar
Idmtboy
K&N has a cool air system that should work, but it will run you about $300. complete.
Old Jan 3, 2013 | 02:27 PM
Idmtboy's Avatar
Idmtboy
This is the one I was talking about
K&N Apollo Universal Closed Intake Systems
Old Jan 3, 2013 | 02:37 PM
Idmtboy's Avatar
Idmtboy
K&N Plenums & Weber Adapter
CUSTOM PLENUM
Cast aluminum plenum, beautifully finished with black powder coating and natural aluminum highlights. The plenum is designed to fit most American 4 barrel carb that have a 5-1/8" flange. Also will fit the Weber DGV carburetor when used with K&N adapter 85-1061. Designed for cold air intake, plenum has a single snorkel outlet that can be fitted with a 4" I.D. hose running to a remote air filter. A K&N universal filter with a 4" flange can also be clamped directly on the snorkel as well. See the Universal pages for filters that will fit onto the inlet. The outside diameter of the plenum is 9" and the snorkel sticks out 6" from the center of the plenum. Minimum clearance required above the carburetor flange is 3-1/8". Customer must provide 1/4"-20 hold down stud.
