Burning oil
Old Dec 16, 2013 | 05:08 PM
Reesey's Avatar
Reesey
Default Burning oil
So i have noticed that my truck is burning oil, verified by a buildup of black deposit on the inside of my tailpipe. What could be the cause of this?
Old Dec 16, 2013 | 05:20 PM
92DakotaClub's Avatar
92DakotaClub
a lot of things.... lol
can be plenum gasket
valve seals
oil rings(piston rings)
head gaskets (rare but can cause oil blow by)
AND MY PERSONAL FAVORITE .. OLD AGE!
running real rich with bad fuel economy .. carbon deposits..
also based on the fact its old it could just be the soot deposits.. if your burning any sort of oil you would see blue smoke either while driving or on start up.. especially
is it a dry black dirty soot..... or is it wet oily soot.. is the question
Old Dec 16, 2013 | 05:45 PM
Reesey's Avatar
Reesey
Its a dry soot, and i get smoke on start up or when a get on the gas hard in nuetral or park. Never notice smoke any other time. Burns about a quart a month.
Old Dec 16, 2013 | 05:49 PM
92DakotaClub
well dry soot is sign of running rich (bad O2 sensors) when u tramp on it if its black smoke its running rich as hell
colour of smoke tells a lot....
Blue burning oil
black RICH as **** unburnt gas
White (normal when cold) but also sweet smell indicates antifreeze in exhaust
Old Dec 16, 2013 | 06:03 PM
Reesey's Avatar
Reesey
Thanks alot bossman. I love the older full steel trucks and I am gonna refurbish this truck, but I want to get it running smooth first. It sat for a year before I bought it. Building a fixit list right now. So far:
AIC
MAP
Torque Converter(temp fixed with Lucas treatment)
u-joints all around
brake booster
o2 sensors
tires all around(bought with perelli racers on it. Not sure what the seller was thinking, living in the northeast with snow)
inside interior
paint job
Nothing to bad. Just wish it was summer out, lol.
Old Dec 16, 2013 | 06:09 PM
92DakotaClub
AIC
MAP
u-joints all around
brake booster
o2 sensors
inside interior
paint job
steel it is .. I built my winch bumper.. T-Boned a 2011 Impala and well lets say I wrote that car off, I drove away needed some more tremclad :O LOL for the bumper
racers? LOL gawd
so u can see mine:
Old Dec 16, 2013 | 07:09 PM
Reesey's Avatar
Reesey
Thats what I am going for. Beautiful truck you have there.
Old Dec 16, 2013 | 08:16 PM
92DakotaClub
Thanks.. my first dodge was an 82 am D150 with slant 6 and 4 speed stick.. then a 2002 quad cab Dakota... figured hey I missed 92 :O worst part is this thing is in better shape then my 2008 :O
I still have a lot to do to get it were I want it to be
Old Dec 17, 2013 | 11:21 AM
Brian in Tucson's Avatar
Brian in Tucson
You're using a lot of oil. Smoke at startup is valve seals and worn guides. Smoke when accelerating is probably seals and guides, too.
Have you done a compression check? You need to do it in two steps, first--engine warm, throttle plate fully open. Second, engine warm, squirt a bit of oil into the spark plug hole (you want to get enough in to seal the rings temporarily) and then crank with the throttle fully open.
Compression should be between 125 & 140 psi. If it goes up after adding oil, it's the rings. Otherwise you have leaking valves.
The thing is about leaking valve seals & guides is that it will destroy the rings fairly quickly. Oil burns a lot hotter than gas, the additional heat damages the rings & causes more cylinder wear & warps them too.
Old Dec 19, 2013 | 06:19 PM
Reesey's Avatar
Reesey
So my compression is at 136psi on avg. Tested three times and thats the average. Lowest test was 132psi. The smoke was from running rich. All my o2s were bad. I did however notice when i opened my oil fill i got a puff of smoke. That cant be good.
