in a 1994 dodge dakota, can I install a 1995 transmission with the electronic control
will the manually controlled tranny be swapped with an electronic controlled tranny if I install the wiring harness and the control module (computer)
Not Identical, they changes the size of a bunch of internal ports in the 95 auto trans. So its probably the same other wise but if you want to do work on it be sure you get 95 specific parts or order according to the number on it.
I went to the junk yard and took the trans out out a 1995 dakota to put into my 1994 and have found it to have an 8 or 9 pin connector on it rather than the 3 pin that mine had. I called the transmission shop and he told me it was electronically controlled where mine was not and would not work. I just need to know if I can make it work by installing the wiring and control module out of the 1995.
The trans out of the 1995 has different internal components when taking off the pan but is a good functioning tranny. Other than the wiring connectors it look as if it will bolt right up. I just don't want to put it in to find I have to pull it and go get another trans
The doner truck is tagged 8 of 95. could some one have already done to the doner truck what I am attempting to do to the 94?
Trending Topics
As in "Manufactured 8/95"? If so, then it's a 1996 Model year.
The VIN will say for sure.
So, I'll bet it's the 4xRE from a 1996, not the 4xRH from a 1995.
To answer your question - Yes, but it's more than just a transmission wiring harness and an ECU; the 1996's got the JTEC instead of the SBEC for 1995.
RwP
RwP
RwP
RwP
