Parking brake release handle replacement 93 Dakota
Greetings all - I'm looking to find a good replacement for the original Parking Brake release handle for the '93 Dakota truck that is a new rehab project for me. The handle that was there broke around the collar. If I can just get a handle that would connect to the existing cable, that would be fine. If it is easier to get a cable assembly that would work, that is fine too, just need to know what would be a good replacement. Thanks in advance!
Just confirming, my pedal is fine. It's the release handle that is broken. That's what I'm hoping to replace (though I could replace the cable assembly and handle both if that is easier...)
So just to make sure, the plastic is broken but the little metal rod that attaches to the cable is okay? Same happened to me so I found a nut that threaded onto the end of the rod and welded a little d ring to the nut. More solid than the original and easier to pull. If you cant weld maybe you can rig something else up just using a nut and a drilled piece of flat steel. Might be more of a hack job than you want to do but if it works it certainly wouldnt bother me. Good luck.
Trending Topics
You got it, it's the plastic handle that is busted. I've seen a couple of possible handles that I could perhaps make work, but I wasn't sure if this was something that I should be able to replace that easily. All I've seen of it so far is that I've got a lump of plastic sitting at the end of the cable. I wasn't sure what is under that lump of broken plastic. So it sounds like I could unscrew the plastic and nut and find a bolt that I may be able to use to hold a new plastic handle on (which might be, for me, as easy as drilling a couple of holes through a plastic handle so I can put the nut into the plastic... One oversized hole to put the nut in that doesn't go all the way through, the other hole straight through to allow the bolt to stick through)
http://www.jegs.com/i/All-American-B...HEB-P/10002/-1
RwP
