Motor Swap
Old Sep 7, 2017 | 08:54 PM
RalphP's Avatar
RalphP
Default Motor Swap
I have found the ideal motor to swap into an early Gen1 with a 3.9 ..
A Dodge Red Ram 241cid (3.9L) Hemi! From 1955 and 1956.
Seriously, though; camshaft is like 2" longer than a 3.9 camshaft; so it looks like using a short shaft water pump (probably a modded SBC pump; the original pump has been NLA for so long, most folks don't even know it HAD a water pump!), and an electric fan.
More info at: https://www.hemmings.com/magazine/hm...i/3730921.html .
Notice how short that motor is overall ... they're known as Baby Hemis for a reason.
RwP
Old Sep 7, 2017 | 09:23 PM
What other parts can't you get anymore?
Dodge made a whole slew of hemis thru the 50's and 60's. I had a "Super Red Ram", that was something like 345 CI. As a basket case, it sold for 500 bucks on Ebay.....
Old Sep 7, 2017 | 09:54 PM
RalphP's Avatar
RalphP
Pistons are available; rods are available; cams are available; valves, springs, rocker arms all available.
There's even a 4 barrel intake for it; that'll fit something like a Holley Sniper or what not for EFI.
Distributors are available (there's a Chevy distributor that fits and works, according to the hot rod sites I pawed through).
I'm not so sure about flywheels, bell housings, et al; or even adapters to fit, say, a 46RH/A518.
RwP
Old Sep 7, 2017 | 10:28 PM
RalphP's Avatar
RalphP
Added: Yep, I can use a 318/360 dizzy.
The 4 barrel intake is still available.
An adapter that uses a A518/A727 transmission is available; also a flex plate to match.
http://hothemiheads.com/dodge/index.html
RwP
Old Sep 7, 2017 | 11:52 PM
Toby Warford's Avatar
Toby Warford
With all that just swap in a 5.3 vortec. At least youd actually have some power and get better mpgs.
Old Sep 8, 2017 | 07:33 AM
RalphP's Avatar
RalphP
Heh. But it wouldn't be a hemi! *grins*
This is a mental exercise; besides, not all motor swaps are just for HP and MPG. That 241 or a 270 would be neat for Just'Cuz.
RwP
Old Sep 8, 2017 | 08:17 AM
RwP
The one complaint I had about those motors was, they were HEAVY. The castings were incredibly beefy. (I think the motor I had was out of a fire truck.....) but, not a lot of power..... of course, that part could be addressed to some extent.
The novelty factor would be off the charts though.
Old Sep 8, 2017 | 09:11 AM
RalphP's Avatar
RalphP
I think you get it *grins*
Pop up pistons to get compression a bit higher than 7:1, a good cam, and pair it with, say, a Holley Sniper EFI setup and a HEI type ignition.
Besides, the burble of a Hemi is ... intoxicating!
RwP
Old Sep 8, 2017 | 10:58 AM
93 ragtop's Avatar
93 ragtop
If you swap to a hemi, or baby hemi, 5.3 GM, 4bt diesel, 5.2-5.9 magnum, I would love to see it and read about it!! Variety is what makes vehicles cool IMO.
If on the other hand, I just wanted what was best, I would go buy a new truck......
Old Sep 8, 2017 | 08:27 PM
RalphP's Avatar
RalphP
Ayep!
The problem for me right now is, I need some monies.
Shucks, I don't have the cash to rebuild the CURRENT 3.9, much less a Red Ram 3.9L V8 *grins*
But that'd be a cool motor in one. Not the fastest, not the most muscular, not the best gas mileage; but cool.
RwP
