check engine light 88 3.9
There is a link to the list of OBDI codes in the FAQ section or you can use this www.dakota-truck.net/CODES/codes.html
It is very weird but my bookmark to the linked page works fine the link is not working from this website. Try copying it and pasting it in a new browser. Copy Paste did not work for me. I noticed that the pasted version was pasted here to read different than what I copied I guess the website prevents certain links. Anayway I rewrote it to be correct so now you can copy it and paste it in another browser.
http://www.dakota-truck.net/CODES/codes.html
Your link still goes to the CGI link, which doesn't work.
(Why, yes, it's in my bookmarks, why do you ask? *grins*)
RwP
Did you also get a 55?
If not, you didn't count the pulses correctly.
If you DID, those two are:
Code Description
46 Battery voltage sense input above target charging voltage during engine operation. (voltage too high) ***
52 A rich air/fuel mixture has been indicated by an abnormally lean correction factor. **
So, I'd check the charging system voltage first; do you have a voltage gauge, and about where is it? (Or even better, check the voltage.)
Again, if you DIDN'T get a 55, then try reading the codes again. You will always get a 55.
RwP
Code Description
RwP
Last edited by RalphP; 12-29-2017 at 07:04 PM. Reason: Fixed table that posted garbled
I think I read the codes wrong. If I read right, the first code was 46, which says charging system voltage too low. I had the battery, starter and alternator tested afternoon. The battery has 12.57 volts, rated at 690 CCA but has 801 CCA. The starter showed 11.27 volts at cranking with a time of 3.80 seconds. The charging system showed no problems with no load on it at 14.02 volts and charging system loaded at 13.92 volts.
46- Battery voltage sense input above target charging voltage during engine operation. (voltage too high) ***
52- A rich air/fuel mixture has been indicated by an abnormally lean correction factor. **
Ralph, I think I copied a link after I searched the number as that shows up CGI on the address bar.
Thanks onemore94dak & RalphP! I will trying reading the codes again in a couple of hours and post results
I think you misread the code list Josh.
This morning on the way to work, I started the truck up and let it warm up for about 10 minutes before driving. About two miles from my house, while sitting at a red light, the truck shuts off with me. It acted & sounded like it wasn't getting fuel. The gas gauge read half-way between 1/2 a tank & 3/4 a tank full. I fired it back up & ran fine. Parked it at work, & before I shut it off, I noticed it idled smooth & perfect.
Keep in mind, I changed plugs, wires, rotor button, cap, fuel filter, and have changed air filters several times since last October.
Any ideas?
Any ideas?
Any ideas?
Any ideas?
A fuel pump that's failing may cut out and then start again without any notice; and if you're low on pressure to begin with, it won't take much to kill the motor.
RwP
