check engine light 88 3.9
Old 01-01-2018, 10:48 AM
Josh89Griffin's Avatar
Josh89Griffin
Josh89Griffin is offline
HeyYou, my speedometer does work, but it chatters bad. I ordered the MAP sensor & will swap that out first.
Does your speedometer work?
Fix the map code first, and see if the 52 goes away.
  #22
Old 01-01-2018, 12:35 PM
onemore94dak's Avatar
onemore94dak
onemore94dak is offline
Remember to disconnect the battery to wipe the codes and drive it a while before checking to see if the 52 comes back.
  #23
Old 01-01-2018, 12:46 PM
RalphP's Avatar
RalphP
RalphP is offline
On a 1988, the speedo is cable driven; even if the VSS has failed, you'll still get speedo.
RwP
  #24
Old 01-01-2018, 06:40 PM
Josh89Griffin
Yes! Hope that the MAP sensor comes in this week & install this weekend
  #25
Old 01-01-2018, 06:41 PM
Josh89Griffin
Two speedometer cables
RwP
  #26
Old 01-01-2018, 08:03 PM
RalphP's Avatar
RalphP
RalphP is offline
One speedo cable; your cruise control module is in the middle of it, causing there to be two cables (trans to cruise, cruise to speedo.)
(It's even kinkier in 1987; the VSS was between the cruise and the speedo! Yoinks!)
And notice how I knew you had cruise from that *grins*
RwP
  #27
Old 01-01-2018, 09:37 PM
Josh89Griffin
Ahh!! What if my cruise control does not work because of a broken cruise cable that goes to the throttle body. I need to look & see which cable goes to the throttle body.
RwP
  #28
Old 01-01-2018, 10:30 PM
RalphP's Avatar
RalphP
RalphP is offline
The cruise control cable to the throttle body is a different cable; but if you pull the cruise servo, you can buy a new non-cruise speedo cable for a 1988 or 1989.
RwP
  #29
Old 01-10-2018, 05:29 PM
Josh89Griffin
Installed an aftermarket MAP sensor, with the negative battery cable off of the negative battery terminal, and the check engine light went off and has not come back on. Just ordered a set of Goodyear Wrangler P235/R7515 tires.
  #30
Old 01-10-2018, 11:38 PM
RalphP's Avatar
RalphP
RalphP is offline
Recheck to make sure that the code is gone.
You SHOULD get a 12 and a 55 (12 for "Battery Disconnected" and 55 for "End of Codes")
RwP
Quick Reply: check engine light 88 3.9
