check engine light 88 3.9
One code you should get every time is a 5 5 ... which is "End of Codes."
If the battery has been disconnected in the last 50 run cycles, you may also get a perfectly normal 1 2 - which is "Battery disconnected in last 50 run cycles."
(The 12 is a problem if nobody's touched the battery; perfectly normal if someone HAS touched the battery cables.)
RwP
RwP
Trending Topics
There is a link to the list of OBDI codes in the FAQ section or you can use this www.dakota-truck.net/CODES/codes.html
It is very weird but my bookmark to the linked page works fine the link is not working from this website. Try copying it and pasting it in a new browser. Copy Paste did not work for me. I noticed that the pasted version was pasted here to read different than what I copied I guess the website prevents certain links. Anayway I rewrote it to be correct so now you can copy it and paste it in another browser.
