440 first gen dakota
I know everyone is going to say theres already a million threads on this but i have not found all the info im looking for
I have a 440 with a 727 and am about to buy a 2wd 87 dakota for fairly cheap .
I would like to use the stock rear end till it blows up, do i have to get a custom drive shaft? Do i have to cut anything out? I can live with out power steering or breaks. I really just want something loud and stupid. Also what do i have to do to get the lights and gauges to work. Looking for guidance from someone who has done it before .
thanks in advance
thanks in advance
thanks in advance
thanks in advance
As for gauges that's pretty simple. The coolant sensor swaps over. The speedo is driven by cable from the trans. Oi psi you can swap over the sensor.
unless you have the rare short tail version (mostly used in motorhomes) 727, it should be very close in length to a 4 speed O/D trans. 87 would certainly be carbureted as original equip, and certainly had a 904 (might be a 998/999 but those are the exact same trans as a 904 just different 1st gear and different number of discs in the clutch packs) A500 didn't come out til some time in 1988. big block into Dakota has been done before. Among others I remember a guy that had a 383 in one.
The wiki may be in error; the 4 speed OD was an option for the 1988 model year; according to my FSM, it occured in about 10% of all 1988 trucks.
RwP
RwP
Trending Topics
I have the FSM for the 87 dakota. FWIW they only show 2 transmissions. 1. NP2500, which is a manual 5 speed. 2. A-998 Loadflite transmission. Says its a 3 speed with a lock up converter.
Hope this helps
Hope this helps
