Need some help from the professionals.
#72
Hey all, sorry for the late reply been busy with life. Well I replaced the crank sensor as well as the distributor pickup plate however I still have the same issue with cylinders 6 & 8 and no engine light on or codes I have even made sure the check engine light works. Could it be possible that there may not be enough pressure getting to cylinders 6 & 8? I know there is the cross tube on the fuel rail could it actually get clogged? Maybe the filter on the intake pump has failed and is letting contaminates in the line? I am just at a complete loss all other plugs look good when checked as well. Also made sure none of the injector wires are crossed.
vizi
vizi
