Where is the the fuse for the overdrive switch in a 91 Dakota?
Old May 19, 2018 | 09:36 PM
Josh pitt's Avatar
Josh pitt
Default Where is the the fuse for the overdrive switch in a 91 Dakota?
My rpms are going way up at highway speeds and check engine light comes on. I’ve replaced the muffler, cat, had the fuel injection flushed and replaced fuel filter in the past two weeks but still having the issue. Today I unhooked the battery for 30min or so, and still no change
Old May 19, 2018 | 10:52 PM
volaredon's Avatar
volaredon
probably either the OD solenoid on/in the trans or the back half of the trans needs freshened up....if I had to guess.....
How many times do you hear/feel it shift?
Old May 19, 2018 | 11:05 PM
RalphP's Avatar
RalphP
And, of course, what codes are produced by the Check Engine Light?
(Use the key dance - take a deep breath, then turn it on/off/on/off/on within something like 5 seconds, and then count the flashes of the CEL. You'll have at a minimum 5 blinks, a short pause, 5 blinks, and no more; you may have a blink, short pause, two blinks, longer pause, then the 5/short/5 pattern - 12 is "Lost Battery Power Within Last 50 Drive Cycles" and 55 is "No More Codes".)
RwP
Old May 19, 2018 | 11:53 PM
Josh pitt's Avatar
Josh pitt
about 3-4 times, it usually never gets up to 3000, if I’m going 65-70, it’s normally at 2200-2300, but now, going 45 is around there, and 55 is right under 3000
im not a car guy, but I can change a fuse, if I could just find the one that goes to it and look at it. Trucks been shocking me lately, left headlight has been replaced 4-5 times in the last two years, it keeps exploding, which has me thinking there something electrical going wrong.
Thanks for the reply 👍
Old May 19, 2018 | 11:56 PM
Josh pitt's Avatar
Josh pitt
RwP
my odometer doesn’t work, and that’s what the mechanic that hooked it up said it was saying
Old May 20, 2018 | 12:10 AM
RalphP's Avatar
RalphP
RwP
OK.
What does that have to do with what I typed?
This is a 1st Gen; the error codes are shown by the CEL (Check Engine Light) blinking after the key dance.
The one that you say comes on in the original post?
Do the key dance, and it'll start blinking at you. Note the pattern of blinks; I'll bet you'll get a 12 and 55 at least, and probably others too.
RwP
Old May 20, 2018 | 01:07 AM
DARKSID3HONDA2015's Avatar
DARKSID3HONDA2015
I'm having same issue it's more then likely your governor solenoid in the trans pan I'm dealing with same issue and thats ehat the code pulled is bad tcc sensor aka governor
Old May 20, 2018 | 10:21 AM
volaredon's Avatar
volaredon
on this series of trucks, most problems I see, don't produce codes...… not like the newer vehicles do. I get more "false codes" like the 37 comes to mind, I think that one is the part throttle unlock for the lockup converter.... another one is something for the AC.
Old May 20, 2018 | 11:03 AM
91 doesn't have a governor solenoid.
Old May 20, 2018 | 03:49 PM
volaredon's Avatar
volaredon
nope. that didn't start til 96.. still a solenoid in there to control the lockup converter
on the speedo not working they had an old school speedometer cable til 93.
