Anyone else adding USB ports?
Old Jan 26, 2019 | 05:31 PM
RalphP's Avatar
RalphP
Default Anyone else adding USB ports?
I ran across this on Amazon - five single port boards, just need wires soldered to them and mounted somewhere.
https://smile.amazon.com/HiLetgo-DC-...dp/B01HXU1C6U/
RwP
Old Jan 26, 2019 | 10:52 PM
tbugden's Avatar
tbugden
Maybe someday. I really only need one though and if I ever replace the head unit it'll have that... **** on that note I just remembered I have a spare head unit in a box! And some good speakers sitting around. Dammit Ralph, you gave me another project.
Old Jan 26, 2019 | 11:36 PM
glenlloyd's Avatar
glenlloyd
Since my cig lighter is defunct I'll have to come up with something and probably easier to just do something like this. I would like to see something like that other one you posted Ralph, didn't that one have two USB ports?
Anyway, maybe in the spring I'll do something.
Steve
Old Jan 27, 2019 | 01:38 AM
RalphP's Avatar
RalphP
Yes, it did, and was a better fit for my plans up high. Those little ones, though ... there's notches at the top of the glove box, you could mount them there (take the trim out with the cupholder to reach in there), wire them to either constant hot or switched hot, and snake the USB cable up into the notch. (I ran some LED pods for a glove box light instead ... that should be finally ready for pics sometime this next week!)
Here's the one I used: https://smile.amazon.com/gp/product/B01IY4QFXE/
Do notice that it's 3A total; the other one is also 3A, but for just one outlet. And it's cheaper per outlet too! (All five run less than this single 2-outlet unit does.)
OTOH - THIS one works, and works great.
OTGH ... with five, you could stick one or two up in the headliner up front, one in back, and two in the glove box ...
RwP
Old Jan 27, 2019 | 10:30 AM
RalphP's Avatar
RalphP
A few more possibilities.
5, 2A singles: https://www.newfrog.com/product/5pcs...charger-146344
A double unit: https://www.newfrog.com/product/dual...-module-261981
And for those that want a really, REALLY bright footwell light - mount this one: https://www.newfrog.com/product/1pcs...-new-208985.01 (Or under the hood. Shucks, put a pair and get yourself a suntan while checking the oil!)
(Yes, that last one is a bit silly.)
RwP
Old Jan 27, 2019 | 05:50 PM
RalphP's Avatar
RalphP
BTW - I've bought from Newfrog before. As long as I understand a) English isn't their first language (and at times, I don't think it even ranks in the top 5!) and b) Ad writers lie worse than politicians, then it's usually OK.
RwP
Old Jan 27, 2019 | 06:31 PM
RwP
Thank You for that. Gave me a good laugh. (mainly because its true.....) Glad I wasn't drinking anything.
Old Jan 27, 2019 | 08:37 PM
RalphP's Avatar
RalphP
RwP
Heh.
Let's say I recommend them with reservations. Main reservation is "Use your brain!"
So far nothing from them's been bad; as long as I read between the lines.
(At least they haven't gotten Wish's reputation ... )
RwP
Old Feb 1, 2019 | 08:47 AM
Ruff16965's Avatar
Ruff16965
I had a dead cigarette socket, replaced it with a dual USB port from Amazon. Works great.
Old Feb 1, 2019 | 01:32 PM
glenlloyd's Avatar
glenlloyd
I like that for replacing the cig ligher but would still need to add one up above mirror and in the rear near the dome light OR back in the bed of the truck for a bed cap mounted camera.
Steve
