At Wit's End With '91
Old Mar 6, 2019 | 03:43 PM
  #21
If it's temp related, more likely a sensor has a bad connection, and if it gets cold enough, it starts working.
If the engine temp sensor has gone bad, plugging in with a scan tool, and comparing what the PCM thinks the temp is, to what the actual temp is, will tell the tale.
Old Mar 6, 2019 | 05:29 PM
  #22
KevinSandidge's Avatar
KevinSandidge
Okay; maybe, finally some good news. Just now the truck was back to crank/no start only this time i finally get a code, 42. Is it bad wiring around the relay box or is it a bad ecm or something else?
Would my switching the relays around cause that code? say no
Old Mar 6, 2019 | 06:13 PM
  #23
Swap the ASD relay with another one. See if anything improves.
Old Mar 6, 2019 | 06:36 PM
  #24
KevinSandidge
did that already and nothing changed. did my switching these up cause that code 42?
Old Mar 6, 2019 | 07:06 PM
  #25
Not likely. If the code was there before, then it's a wiring problem. (or PCM.....)
Old Mar 6, 2019 | 07:45 PM
  #26
KevinSandidge
[QUOTE=HeyYou;3431474]Not likely. If the code was there before, then it's a wiring problem. (or PCM.....)[/QUOTE
From the start, i never got more than a code 12. this is the first time for the code 42.
Old Mar 7, 2019 | 09:18 AM
  #27
Could be a bad relay then.
Old Mar 7, 2019 | 09:53 AM
  #28
KevinSandidge
Thanks; i'll take my relay back to napa and see if they can find it this time and if the proper relay dont fix the truck then i guess i'll wait on my buddy to come and check voltages and maybe take apart and look at that 'splice' and/or buy a new pcm if i have to. thanks again
Old Mar 7, 2019 | 11:21 AM
  #29
KevinSandidge
Found the correct relay. i took the battery cable loose and put the relay in. reconected battery and the truck started(for all i know it would have started anyway). so it starts easily and let it idle and a few minutes later it dies. i crank it again and this time i have to give it some gas and it starts only to die again. im sick of this s
Old Mar 7, 2019 | 06:59 PM
  #30
Will it stay running if you keep your foot on the gas?
