rear differential
Old 08-03-2019, 05:50 PM
SRAC76's Avatar
SRAC76
SRAC76 is offline
This is why you need to say what you have. I didn't know it was 4X4. Your differentials need to be gear matched. For a 3.55 rear end, you'll need 3.54 in the front to keep the transfer case from over running.
I stated on the first post that I needed a rear differential with 3:90 gear ratio.
Old 08-04-2019, 01:34 AM
ol' grouch's Avatar
ol' grouch
ol' grouch is offline
3.90 was available in 2 and 4wd. Dodge has cut back on ratios. I've had everything from 2.73 to 5.88 gears from the factory.
Old 08-04-2019, 07:23 AM
93 ragtop's Avatar
93 ragtop
93 ragtop is offline
Not sure how much you want to change the truck, but you may consider a newer dakota with the 9.25 ratio. Its my understanding that they will bolt up to your existing leaf springs, and the driveshaft hooks up.... May have to make up some of you brake line, and may have to do something with the emergency brake cable.
Just a suggestion if you cant find a good 8.25 rear....
Old 08-04-2019, 09:38 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,270 Likes on 3,017 Posts
9.25 rear diff, but 3.90:1 gear ratio.
Old 08-04-2019, 01:38 PM
93 ragtop's Avatar
93 ragtop
Yes, that is what I was thinking.... Just a quick search shows (chryslerfactoryparts) a 2000 4.7 manual trans. used a 9.25 3.92 ratio...... Dont know what others though....
Old 09-29-2019, 08:00 PM
SRAC76's Avatar
SRAC76
SRAC76 is offline
Default Update
So after I found the rear diff and pulled it at a wrecker/junkyard I discovered that the transfer case was fused and I had to replace it ( no way to rebuild due to the craptasic state it was in.) Got a used rebuilt one for $275 and installed it. Yay it is now up and running though I did notice that the front drive shaft was missing. Apparently it was sitting on the floorboard in the back of the cab.. why would somebody take it off?? Just a weird...
Old 09-30-2019, 05:07 AM
ol' grouch's Avatar
ol' grouch
They probably pulled it when the transfer case wouldn't release it.
Quick Reply: rear differential
