Alternator Upgrade?
Old Sep 2, 2019 | 09:27 AM
93 ragtop's Avatar
93 ragtop
Default Alternator Upgrade?
I have a 87 dakota V6 with a 78 amp alternator. I have added 2 electric fans, in place of the mechanical fan...... They pull about 16.5 amps each. I am setting them up to run first stage, (1 Fan) second stage (2 fans).
Now to my point, Truck seems to be charging at 14.3 volts with engine around 1000-1500 rpms?
But when the AC is on, both fans running, Im reading 12 volts at the battery, idleing the motor.....
It appears, rockauto offers a 120 amp double pulley alternator. I suspect this would be enough.
Would I need to change wiring other the the battery feed to the alternator?
Also, with a pulley change, would this alternator mount to a magnum engine accessory drive? I plan to eventually put a 5.9 in the truck, but will not be using the magnum FI system, so the regulator will stay external.
One last question, are there any good 1 wire conversions I should consider?
Thanks
Old Sep 2, 2019 | 09:52 AM
What optional alternators were offered on your truck from the factory?? I suspect there will be something north of 100 amps for trucks that had various two/heavy duty packages......
Old Sep 2, 2019 | 12:09 PM
RalphP's Avatar
RalphP
Upgrade the wiring around the alternator to 4ga or larger first (read up on "the Big Three"). Upgrade the battery cables. THEN swap on the 120A alternator.
RwP
Old Sep 2, 2019 | 01:56 PM
93 ragtop's Avatar
93 ragtop
Not sure.....
When I look at the FSM they show a 78 amp external regulator....
Then they list 50/120 amp alternator with voltage regulator in engine electronics....
I assume the 78 amp was on the V6 as it had a carb.....
50/120 was on the 4 cyl? but again, I assume.
FWIW mine was a late model (april 87)
Back on track, when looking at rockauto, they only show 2 for the V6 90amp or 120 amp.
Old Sep 2, 2019 | 02:03 PM
93 ragtop's Avatar
93 ragtop
RwP
I got to figure out what the big 3 is..... The battery cables, I swapped to heavier ones a few years ago.
The 120 is what I will probably end up doing,
Do you know if it will mount on the magnum accessory drive, and be able to switch the pulleys to the serpentine style?
It would be nice to be able to reuse the alternator on the magnum if I am able to swap motors this winter.
BTW it will not have the dodge computer when I swap. Planning a holley 670 street avenger carb. (I already have) and an electronic ignition....
Old Sep 2, 2019 | 02:20 PM
RalphP's Avatar
RalphP
I'm not sure, but when looking for a replacement while troubleshooting a fusible link problem (which turned out to be a failing relay!) AutoZone kept pulling up alternators with a serp belt pulley on it; plus JSA's alternators can be had with the double-V pulley.
Here's from an email I got from them (sale price may not be in effect anymore):
we offer
240amps $359, sale $299
300amps $459, sale $399
powdercoat $45
Lifetime Warranty
to order, we send invoice to your email,
you can pay with any card or paypal
That was at https://js-alternators.com/ .
I landed there looking for something better than a 105A for my wife's 1991 Cougar.
RwP
Old Sep 2, 2019 | 03:04 PM
3.9 V-6 right? Same engine/bracketry that was used on the full-sized trucks?? Get an alternator for a full-sized truck.
Old Sep 3, 2019 | 07:40 AM
93 ragtop's Avatar
93 ragtop
I did look at that..... Basically showing the same for both full size and dakota. But thanks
Old Sep 3, 2019 | 07:56 AM
93 ragtop's Avatar
93 ragtop
Hey Ralph,
I "think" the big 3 you were talking about is basically upgrading the postive cable, negative cable, associated grounds, and the alt. feed to a larger size... Is this correct?
I cant find a listing in my FSM showing ga. size of the cables....
Assuming I can use the 120 amp alternator, would you mind answering the following questions?
1. What size neg. cable to battery?
2. What size pos. cable to battery?
3. What size feed from alternator? I believe you already said, "at least a 4ga. on that one"
FWIW, I believe I can get the 120 amp through advance auto for about $80.00.... but another concern is, the 120 used an external fan vs the 78 using an internal fan.... Hopefully it will mount up, and the pulleys will align...
Old Sep 3, 2019 | 08:21 AM
ZEN357's Avatar
ZEN357
Several to choose from for your model year.
https://www.rockauto.com/en/catalog/...generator,2412
