Need help finding rear rotors 6x4.5 to fit my 92 dak.
Old Jan 31, 2020 | 01:11 PM
93 ragtop's Avatar
93 ragtop
Can you post any casting numbers, ie on the caliper or rotor?
Old Feb 1, 2020 | 01:01 AM
Devon Farber's Avatar
Devon Farber
Default 6x4.5 Frankenstein
Originally Posted by Devon Farber
it's got 5x4.5? Rear 99 ford exploders. Can only land on a .5solid rear plate(2in hiegt total od 11.3) it's drilled out to 6x4.5
Update.. Way too much hassle . what if I find caliper brackets to mount Durango calipers? Seems they have 6x4.5..would definitely rather run all dodge and way less hassle? How or where do I look?
Old Feb 1, 2020 | 02:23 AM
Devon Farber
Thank you all for all your response to my post. I'm still learning this forum (site. And on a
phone ) help with caliper brackets to mount Durango calipers? viper?
it's drilled out .5 solid ford explorer pads and rotors is ridiculous. Super nightmare timing on this. Having shaved beyond limits and 2mm left scorned .close to failure. Smelled em today smoking.
I've never done caliper brackets swap. Need dodge 6x4.5 complete brake kit for dana60 Dynatrac axles. And rear did tags were useless..
Old Feb 1, 2020 | 03:29 AM
Devon Farber
Originally Posted by onemore94dak
The question that comes to me is; What rotor do you have now? Can you identify it? If not can you post a picture so the people who might know can try to identify it?
ford explorer 99
Back pad set up tolerance check befor i threw th old back in
Old Feb 1, 2020 | 03:44 AM
Devon Farber
I will soon. Dodge up front explorer rear
Old Feb 1, 2020 | 03:49 AM
Devon Farber
Something is not right...... You said it was a solid rotor, and your picture is vented...... Explorer has a solid rotor.
That caliper does not look like a explorer. Enclosed is a picture of a 8.8 out of a explorer in my truck.... The second picture shows the explorer rotor is solid.. The third picture is the best I have of the caliper on the inside.
Are you sure that is a dana 60? If you could show a picture of the diff. cover it would help....... so we could see the bolt pattern.
Any chance what you have is a 9.25 out of a 03 or so dakota or durango? It looks more like that too me. But the pictures you supply are hard to tell much from.
so nice. Yes please allow me to look properly. I will take Accurate information and upload the photos.
and I've only gotten this knowledge by what I've been told. So thank you
Old Feb 1, 2020 | 08:08 AM
Have you tried calling Dynatrac???
Old Feb 1, 2020 | 10:31 AM
onemore94dak's Avatar
onemore94dak
That rusty rotor looks good enough to have it turned and reuse it. Is there something else wrong?
The pictures don't help identifying the rotor. Maybe post some clear ones of the rotor by itself.
You probably thought of this and can't do it but I would try to contact the previous owner to ask them what they used just so you know even if you do turn the ones you have and get it on the road.
Old Feb 4, 2020 | 10:04 PM
Devon Farber
Who did the axle swap? Or the brake swap, as the case may be.....
Old Feb 4, 2020 | 10:25 PM
Devon Farber
Ford exploder pads? Model says ram 2500 on dif.
