So what are you doing?
Old Aug 31, 2020 | 01:57 PM
  #91
ol' grouch's Avatar
ol' grouch
We've been lucky here. No major storms with widespread damage in a few years. One more winter and I won't have to work in it.
Old Sep 6, 2020 | 05:21 PM
  #92
RalphP's Avatar
RalphP
Today - new spark plugs, resealed the A/C, and sucking it down.
Also lining things up for next weekend to do the rear transmission bushing and seal.
Fastening the passenger dash trim back in place; if I get the A/C blowing cold I'll put the IC surround back on too.
(If I get that far, I'll take a pic of my "new" speedometer installed, too.)
RwP
Old Sep 8, 2020 | 04:09 PM
  #93
93 ragtop's Avatar
93 ragtop
Hey Ralph,
Got a few more goodies!...... Getting ready for that swap!
Old Sep 8, 2020 | 05:03 PM
  #94
RalphP's Avatar
RalphP
Looking good!
Don't forget the orifice tube / thermonic expansion valve and the receiver/dryer / accumulator (depending on which of each is appropriate for your year truck).
Discovered two missing vacuum caps today; even with them on, I don't get but 15in vacuum.
Old school troubleshooting chart says that ignition is probably retarted from ideal; which makes sense.
i'm going to adjust to about 14* to 16* BTDC on my motor (which I can do, it's an LA, not a magnum!) and just run midgrade or premium fuel in it.
But it sure blows cold air today!
RwP
Old Sep 15, 2020 | 07:45 PM
  #95
RalphP's Avatar
RalphP
FINALLY got around to installing the backlit faces on my spare gauge cluster, so I can start rewiring the truck to use a 91-93 tach cluster.
Problem now is a good 1000-1800 RPM motor with a 1/8 drive shaft that can run for about 200 hours non-stop (120 or so if 1800 RPM) to bring the odometer up to my current setting. But it's a start!
(That 1000 RPM behind it as I took this picture warms up too much too fast; it's not designed for 24/7 operation, alas.)
RwP
Old Sep 15, 2020 | 07:47 PM
  #96
Lites not working on the top two gauges??
Old Sep 15, 2020 | 08:18 PM
  #97
RalphP's Avatar
RalphP
Yah, during the last two years the plug on the end pulled off, so I can't plug it into the control box for the backlight. Yet. Amazing what a supply of small 2 pin male/female connectors and a hot soldering iron can do, though.
I also have some needle paint to redo the needles on the tach and the other four gauges.
Since my truck wasn't equipped with the optional tach, I don't expect to have the tach pulses (optional as in "Hey, let's start offering this on the last 100 or so Dakotas for 1988 before we make it official for 1989!" optional) off any of the SMEC pins; since the tach expects two pulses per revolution, I have an adapter already set for a 3:2 ratio to tap into the coil feed with.
When done, it should be a nice improvement over the factory 85MPH cluster (which I have a 125MPH speedo in there; it's just a few miles low from the current odometer setting, like about 9,600 ... )
RwP
Old Sep 15, 2020 | 10:14 PM
  #98
RandoRemi's Avatar
RandoRemi
Talking
Got all the lights in my dash replaced. Shines bright!
Only problem is that the ABS light and E break light is on now. The ol' 1 problem into another.
Old Sep 20, 2020 | 01:57 PM
  #99
RalphP's Avatar
RalphP
Had to replace the lift cylinder on my chair. Again.
The one I bought was about $30, but came with a neat kit to help get the old cylinder out.
I can find them for $16, but the last one lasted less than a year, and was $16, so ...
(I'm about 345 now, so I only buy the 450lb lift cylinders. I think that last one was not quite honestly rated ... )
RwP
Old Sep 21, 2020 | 08:51 AM
  #100
ol' grouch's Avatar
ol' grouch
I replaced the timing chain my my pickup. I was hoping to do it without dropping the oil pan. No soap there. I see some other stuff that needs attention so I'll take care of them while I have the truck up.
