Pics of my new (to me) engine
Old Oct 11, 2020 | 07:29 AM
93 ragtop's Avatar
93 ragtop
Default Pics of my new (to me) engine
Just wanted to share some pictures of the 5.9 I been slowly working on.....
This coming week, I hope to get started on swapping my 3.9 for this 5.9!!
3 pictures of the engine when I purchased it.
And 4 pictures after a backyard rebuild.
Old Oct 11, 2020 | 08:33 AM
The "after" pics look a lot better.
What intake are you using?
Old Oct 11, 2020 | 11:18 AM
93 ragtop's Avatar
93 ragtop
Thanks, that is a Edelbrock 7577........
Old Oct 12, 2020 | 09:55 AM
That should give you some good power. When are ya gonna get it installed?
Old Oct 12, 2020 | 10:35 AM
93 ragtop's Avatar
93 ragtop
Hopefully start on it this week!
The engine, is all stock, other then the intake, carb, and dist.
I put a turned crank in it, 10-10
Used some aftermarket heads, which I believe are chinese castings, but finished in USA
Put cam brgs, timing chain, freeze plugs, etc. but kept stock cam. and pistons.
Hopefully it runs ok and does not smoke..... I just re-ringed....
Oil pressure was 70 with a 550rpm drill and 5-30 oil.
Old Oct 12, 2020 | 01:35 PM
Was the block bored at all? If it was, you are going to want oversize pistons in there as well.
Old Oct 12, 2020 | 02:00 PM
93 ragtop's Avatar
93 ragtop
No, the motor had never been apart. I just cleaned up the pistons, light hone, and installed new rings.
Old Oct 12, 2020 | 02:03 PM
Should be golden then.
Old Oct 13, 2020 | 07:41 AM
93 ragtop's Avatar
93 ragtop
I hope!! I would have liked to have it bored,..... a little more cam, and springs, but at some point, ya gotta stop spending! I already have about $2,000.00 in this engine.
Old Nov 24, 2020 | 04:09 PM
93 ragtop's Avatar
93 ragtop
Well, I finally got the engine pulled out of my truck.
Now to clean up, paint, and replace.
