New guy -- no headlights, brake lights, or horn!
Quote "Good for you, I just got in a copy of the 1991 factory service manual.
ALL of your affected circuits are fed by fuse G in the PDC under the hood.
So - step 0. Check ALL of your fuses.
Step 1 - Follow the 12ga red wires from the PDC - one goes to the ignition switch, the OTHER one is the one you want.
Checking the bulkhead fitting for corrosion is also a good thing to do.
DO remember, disconnect the negative battery cable from the battery BEFORE checking anything. And reconnect before trying to drive it.
RwP"
End Quote
My questions -
First, checking the bulkhead fitting for corrosion, I checked the bulkhead fitting on the passenger side and it does have some corrosion, Is this fitting for the fan?
Second, on the inner fender there is a something that looks like a fused link but actually has a contact point which I assume opens at some time. The actual part was out of its container and the wire folded and hanging. Why would anyone do this?
RwP"
End Quote
My questions -
RwP"
End Quote
My questions -
RwP"
End Quote
My questions -
