Weight Capacity
Old Mar 22, 2021 | 11:37 AM
bronze's Avatar
bronze
Default Weight Capacity
1993 Dodge Dakota, Ext Cab, 5.2L, Rear Wheel Drive, Auto Trans
Anyone know how much weight I can safely put in the bed without trashing my truck? Need to get some pea gravel. Gravel probably weighs 2,500 lbs per cubic yard. Pretty sure I don't want to do that but thinking I could handle a 1/2 cubic yard at 1250 lbs. No passengers, no other crap in or on the truck, just me and the gravel.
Old Mar 22, 2021 | 12:27 PM
RalphP's Avatar
RalphP
Well, first off, what's the GVWR on the door sticker?
I'd go off of that.
But yes, the Dakota was supposed to be a 1/2 ton pickup, so 1250 lbs should be OK. BUT. Do a once-over to make sure you don't have any broken springs in the back etc.
Addendum: Fill the back tires to the sidewall max also. And make sure to take it slow and easy while driving; don't tailgate, don't push it, don't mistake it for a C8 Corvette or some other great handling sports car.
RwP
Old Mar 22, 2021 | 02:56 PM
bronze's Avatar
bronze
I'd go off of that.
RwP
Yeah, my GVWR is 5200 lbs but problem is I don't know what my truck weighs to know the difference for load capacity. But I kinda feel relatively safe at 1250 provided I don't drive like a raped ape. Just nice that someone else agrees.
And your advice to take it easy is good with or without gravel in the back end.
Old Mar 22, 2021 | 04:47 PM
93 ragtop's Avatar
93 ragtop
For comparison...... My 87 standard cab long wheel base 4 WD 5 speed v6 with me and half tank of gas is 4060....... I'm 200 of it.
Old Mar 22, 2021 | 05:02 PM
bronze's Avatar
bronze
That sounds about right. That would leave about 1200 load capacity per spec.
Old Mar 23, 2021 | 06:24 AM
ol' grouch's Avatar
ol' grouch
I have a 5X10 utility trailer I pull. I've had it for 30+ years. It can carry more, if I don't unload it all the way I can unhook it and the bucket is away from the truck when they dump the load into it. It ran me $500 and they don't run much more than that now. About $700 now. It has a 3500 pound axle and weighs around 500 pounds. With 3000 pound plates I can legally haul 2500 pounds. Plus, I can take my time loading it.
Old Mar 28, 2021 | 02:03 AM
crazyjerry's Avatar
crazyjerry
before i sold my 96 4x4 xtended cab i hauled some dirt and was 800lb over gvwr. only drove about 15mi but it was fine. 1200lb would be fine but i wouldnt go any higher
Old Mar 28, 2021 | 09:20 AM
93 ragtop's Avatar
93 ragtop
I put 2404 lbs on mine!! But.... went a short distance, on hardtop, and most of the weight was to the front. Would not suggest this to be tried!!
https://dodgeforum.com/forum/1st-gen...kota-haul.html
Old Apr 1, 2021 | 01:25 PM
bronze's Avatar
bronze
For the record as the OP of this thread...
I had a half cubic yard of pea gravel loaded in my truck. It was uniformly spread front to back. Aprox weight of gravel: 1,300 lbs. It handled it fine. Definitely knew I had something back there but did not bottom out the shocks/springs or point the front toward the sky. Drove moderately and did not get crazy. When I pulled in the gravel yard I told the guy I wanted some pea gravel and he said (before I did) "A half yard". He knew what it could handle and probably wouldn't load more even if I asked. I concur...1,300 lbs is fine but I would NOT recommend more.
Thanks for your input fellas.
Old Apr 1, 2021 | 08:07 PM
Your yard guys are obviously smarter than the ones around here...... I went to get some topsoil, the loader guy put two scoops into the bed. It didn't *look* like a lot, but, the scale said 5000 lbs........ (3/4 ton truck) of dirt in the bed.... The front was EXTREMELY squirrely, and I don't think there was much suspension travel left in the back.... Fortunately, I didn't have to go far, and I didn't go any faster than about 30mph........ The next time I went to get topsoil, I went with a dumptrailer, with brakes...... MUCH better experience.
