94 GMC 1500 NV3500 work for 92 Dakota?
#33
As to brand of injectors - I would probably stick with a Bosch or Siemens injector, and new.
So far the ones I've bought from Five O Motor Sports have been good units; but there's several other companies out there. Five O's link is here DODGE DAKOTA 1994 V8, 5.2L, Y, GAS Fuel Injectors (fiveomotorsport.com)
(I'm saving up for some new Deka 80lb injectors for my Cougar - primarily because the genuine Deka 80lb injectors are so linear, with almost no ramp up curve, that they're very VERY easy to program for; but without programmability, you don't want them on your Dakota.)
RwP
#34
This is just my opinion, but I would try to make sure the mechanical driven speedometer can be adapted to the VSS style, even though the VSS is gear driven, I would want to make sure the "mechanical speedometer cable adapter?" from the earlier trucks would fit the newer transmission.....
Also, I dont understand the need for a different ECM especially if it requires new injectors, and a fuel pressure regulator.
I thought on the 92-95 automatics (RH series transmissions) The only control of the ecm was converter lock up and overdrive.
I would try it and see what happens, then if a code is set, deal with it then, but even at that, I would think that taking the 2 solenoids out of your automatic, and plugging them into the harness would eliminate that problem....... But I could be wrong
The following users liked this post:
RalphP (05-20-2021)
#35
#36
But you WILL get CELs if the engine speed doesn't change to match the lock up and overdrive command ...
SO it's a matter of ignore them, or figure a way around.
(Me? I'm a computer tech, used to diddling bits - I'd look at converting to a Ford EEC-IV or EEC-V, with a Moates QuarterHorse installed, so I can diddle with THOSE, since I have source code and all kinds of files to tune those ECUs ... but that's me.)
RwP
#37
I took a look and found this website called Novak conversions for AX15’s, I’ll have to weigh my options, I don’t really want to get to custom with injectors and ECM. But that said as I slowly work through renewing the truck with new parts ( ie got new carpet, window weather stripping, unfortunately can’t get the window beltline, etc...) I’ll probably also look into these injectors weather from 94/95 w/adj regulator? Before I even do the conversion, Seems best I aim to find a tranny from either a 92/93 (AX15), I am assuming the VSS would be same setup and location? and address the lockup & overdrive on my ECM (as noted above) or do the 94/95 get a ECM although reading up on NV3500 from those years there were improvements in quieter and smoother running.
#38
