'96 3.9L Fuel Injectors?
Old May 13, 2022 | 12:04 PM
Dibbons's Avatar
Dibbons
Default '96 3.9L Fuel Injectors?
Does a Dakota first generation 3.9L magnum (1996 year model) have fuel injectors that would need to be cleaned or replaced? Thank you.
Old May 13, 2022 | 12:29 PM
It does indeed have injectors. Six of 'em. Cleaned or replaced? That depends on if they are giving you a problem. They are pretty reliable...... What problems are you having?
Old May 13, 2022 | 08:31 PM
Dibbons's Avatar
Dibbons
No problems, just thinking maintenance for now.
Old May 13, 2022 | 09:00 PM
If it ain't broke, don't fix it.
Old May 13, 2022 | 09:08 PM
bronze's Avatar
bronze
Agree with HY especially as it pertains to injectors. Fuel these days from reputable gas stations generally do not foul up your injectors. So leave ‘em alone. If there ever is a problem with them it will let you know. I’d be more inclined to change the fuel filter before monkeying with injectors. Fuel filters are regular maintenance items. And not a hard job.
Old May 13, 2022 | 09:17 PM
I suspect his filter is in the tank, and part of the fuel pump module... so, not cheaply replaceable.
Old May 13, 2022 | 09:53 PM
bronze's Avatar
bronze
Originally Posted by HeyYou;[url=tel:3543861
3543861[/url]]I suspect his filter is in the tank, and part of the fuel pump module... so, not cheaply replaceable.
Mine is along the frame on my ‘93 and I assumed it would be the same on all the 1st Gens. But what do I know?
Old May 14, 2022 | 09:07 AM
Interesting. The 93 should be the magnum variant of the motor as well, isn't it??
Old May 14, 2022 | 11:14 AM
bronze's Avatar
bronze
Yepper
Old May 14, 2022 | 11:26 AM
Huh. Odd. Wonder when they went to the internal filter on the Daks...... (I haven't worked on any in a LONG time. )
