1993 Dodge Dakota 318 V8/5.2 liter with 46RH/A518
Old 12-27-2022, 02:44 PM
Lizard King's Avatar
Lizard King
Lizard King is offline
Default 1993 Dodge Dakota 318 V8/5.2 liter with 46RH/A518
Hello, I've been having transmission issues and I'm trying to figure what the issue is so I'm going to put the down the symptoms below and see what the general consensus is. 1st and 2nd work pretty good but it's 3rd/OD that is acting very wonky. Whenever you first start it up and go for a drive... you have to bump the gas real harshly or stomp the gas and then let off for it to shift into 3rd/OD. But after about 5 minutes of driving or after it gets warmed up pretty good... it doesn't want to shift into 3rd/OD at all. The fliter/fluid and gasket has been changed out and while that helped, that did not solve the issue... does the bands need adjusting or could it be the OD solenoid need replacing? Please let me know what you guys think below.
Old 12-27-2022, 06:26 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,190 Likes on 2,943 Posts
If you aren't getting third gear, you won't get o/d either. Adjusting the bands *might* help, but, don't hold your breath.... Recheck fluid level though, gotta check in neutral, checking in park gives an artificially high reading.
The following users liked this post:
McBroom (01-05-2023)
Old 12-27-2022, 09:38 PM
Lizard King
Alright, I shall do that... thank you for the kind advice stranger.
Old 12-27-2022, 11:00 PM
HeyYou is offline
Hey now. No stranger than anyone else here.... Maybe.....
The following 2 users liked this post by HeyYou:
McBroom (01-05-2023), tndakman (12-28-2022)
Old 12-28-2022, 06:09 AM
bronze's Avatar
bronze
bronze is offline
That’s debatable.
Old 12-28-2022, 09:55 AM
Jaddrockguy96's Avatar
Jaddrockguy96
Jaddrockguy96 is offline
Depending on how it shifts into the gears may want to check the throttle valve/kick down cable and adjust as necessary. Just to cover all bases.
Old 12-28-2022, 10:08 AM
Lizard King
I'll definitely do that as well, 1st and 2nd kick in really well but like I said it's only 3rd/OD this isn't working right... you think maybe even messing with the accumulator springs might help a lil bit?
Old 01-02-2023, 11:21 PM
bronze's Avatar
bronze
bronze is offline
Originally Posted by Lizard King;[url=tel:3557467
3557467[/url]]I'll definitely do that as well, 1st and 2nd kick in really well but like I said it's only 3rd/OD this isn't working right... you think maybe even messing with the accumulator springs might help a lil bit?
it’s cheap enuf and while you’re there…
Quick Reply: 1993 Dodge Dakota 318 V8/5.2 liter with 46RH/A518
