Help me source 96 5.2 auto engine harness?
Old Aug 26, 2023 | 11:03 AM
Breezy134's Avatar
Breezy134
Default Help me source 96 5.2 auto engine harness?
Been looking daily for a while now… can’t seem to find this harness anywhere. Is there any interchangeable part #’s?
can I use a 96 ram harness in here? Or is the bulkhead connector different? Thanks in advance.
Old Aug 26, 2023 | 02:24 PM
You aren't going to find one new. At least, not without a major stroke of luck..... Used is possible, but, ya never know what yer gettin' there.. What's wrong with the current harness?
Old Aug 26, 2023 | 04:32 PM
Breezy134's Avatar
Breezy134
I’ve already repaired it upwards of 4x to fix issues, including splicing in new PCM connectors, then I find corrosion or shorts somewhere else. Literally done putting the time into it.
Old Aug 26, 2023 | 04:35 PM
bronze's Avatar
bronze
You could always make your own else it's the scrap heap.
Old Aug 26, 2023 | 07:39 PM
onemore94dak's Avatar
onemore94dak
Try searching "complete auto wire harness" there is a bunch of stuff. I just found this; https://kwikwire.com/collections/com...ew=bc-original If I knew enough about it I'd fix my other rig
These guys website date only goes up to 91 but you may have luck getting info or ideas from them. https://www.painlessperformance.com/wc/mopar
Old Aug 28, 2023 | 09:52 PM
Flounderguy's Avatar
Flounderguy
I had multiple problems with the harness on my 95, 5.2. I ended up replacing about 1/3 of the harness. But, it turns out my major problem was that every time I used my multimeter for testing, I was stretching out the female pins on the 60 wire PCM connector. I pulled out each pin and either squeezed it tight again or replaced it. No problems since then. I looked for a replacement harness too but couldn’t find one.
Old Aug 28, 2023 | 10:57 PM
bronze's Avatar
bronze
Were you releasing the pins from the connector first? Those little tabs inside that hold them in?
Old Aug 29, 2023 | 04:42 PM
Flounderguy
No, I just pressed the end of my multimeter into the female pin of the connector. I pulled the pins out one at a time when I fixed the connector. After that I got a kit of pins for back probing. Back probing is much easier.
Old Aug 29, 2023 | 09:47 PM
bronze's Avatar
bronze
I guess I’m curious as to how you removed the female terminal from the connector without breaking the flimsy little plastic tab that holds the terminal inside the connector. I ask because I had to replace my connector a few years ago because of my lack of knowledge. I completely destroyed the connector trying to remove the terminals. I learned on the replacement and made my own “tools” to keep from busting those little holding tabs.
Also curious what you used for a probe when backprobing. Thx
Old Aug 29, 2023 | 10:27 PM
Flounderguy
A while back, I was getting some parts from a 95 at Pick and Pull. I happened to glance at the PCM connector and thought it might come in handy. I think they charged me five bucks. So when I started working on my wiring harness, I practiced on the spare connector first. After carefully prying off the red plastic bracket that holds the pins in place, I became pretty adept at gently removing the female pins with tiny screwdrivers. I did break the red plastic bracket in a couple places. But, I had a spare and I super glued the broken back together. It was a very tedious job removing those 55 or so pins. I had the harness on a workbench with the connector clamped so it wouldn’t move. I had really good lighting too.
I looked for a long time for replacement female pins. I could not find them anywhere. I would have tried Fry’s but we don’t have one here. I would think a big electrical supply house would stock them, but I couldn’t track them down.
