Help With Gauges
Old Jan 21, 2024 | 09:13 PM
Leftysdad's Avatar
Leftysdad
Default Help With Gauges
All 4 of my gauges on the right side of cluster are pegged and not working....everything else on the cluster works perfect....just these 4....any suggestions?
Are they all tied in?
Thanks in advance
Old Jan 22, 2024 | 07:34 AM
What are you driving?
Old Jan 22, 2024 | 07:37 AM
Leftysdad's Avatar
Leftysdad
96 dakota 3.9
Old Jan 22, 2024 | 07:39 AM
Ok, your gauges are 'direct read', as in, they get what they are supposed to display directly from the sensors. Since all four of 'em there are not working properly, that's gotta be something with the cluster..... I would be tempted to pull it out, check connections, and give it a thorough inspection for any possible problems. (burnt circuit board, for instance...)
Old Jan 22, 2024 | 01:46 PM
Leftysdad's Avatar
Leftysdad
All connections are good on the back.....I'm going to try and find a cluster to swap and see.....also, what is this.....is making a noise, like surging/thumping sound.....thanks
Old Jan 22, 2024 | 02:09 PM
Don't know on that, should show up on the vacuum diagram though??
Old Jan 22, 2024 | 05:20 PM
onemore94dak's Avatar
onemore94dak
That thing looks like the vapor canister purge valve.
Old Jan 22, 2024 | 09:32 PM
Leftysdad's Avatar
Leftysdad
That's what it is.....I've read the "clicking " sound I'm hearing is normal, and I've read its not.....don't know which, lol
Old Jan 23, 2024 | 09:59 AM
It's a 'duty cycle' solenoid. So, the clicking is indeed normal.
Old Jan 23, 2024 | 10:53 AM
ol' grouch's Avatar
ol' grouch
Charcoal canister purge valve.
