missing on start?
Old Apr 6, 2026 | 05:35 PM
onemore94dak's Avatar
onemore94dak
Default missing on start?
I just went to the grocery and when I started to come home it acted like it is missing. Maybe even more than one cylinder. As I revved it and rolled through the lot it finally came up to running right. I'm letting it cool before I check the oil. How do I diagnose what the problem is if it has enough oil?
Edit- 1994 3.9 Magnum
Old Apr 6, 2026 | 08:51 PM
What year is your dak? Check engine lite on?
Old Apr 7, 2026 | 08:41 AM
onemore94dak
Originally Posted by heyyou
what year is your dak? Check engine lite on?
1994 3.9 I did not notice any dash lights. When the sun comes up I will check the oil and start removing plugs to see what they are doing.
Old Apr 7, 2026 | 11:43 AM
onemore94dak
OK. cyl 2 plug was clean. When the plug boot came off cyl 4 it left the connector behind. The plug had oil on it. Cyl 6 plug was also oily. Cyl 5 plug was oily. Cyl 3 plug was oily. Cyl 1 boot came off leaving the connector behind. Plug was oily. By oily I mean at the bottom thread, the tongue(?) and post was dark but no build up.
I deduce from that that the wires are a problem if not the problem. Those were the spendy 8mm wires from RA. Anyone have a store bought recommendation? The wires won't slide in the boot so I can't repair them. Seems like that was the tuneup that won't stop giving.
Old Apr 7, 2026 | 12:23 PM
I just grab some decent 8mm wires from my local parts store..... May wanna change the plugs as well?
Old Apr 7, 2026 | 04:45 PM
onemore94dak
o'Reilly's was closest. I did not specify past the vehicle and they were $52 lifetime guarantee.
Got home none of them were the same length, short by inches, as the ones I had which were as short as possible. Went back, they had to order new ones, got a refund.
Went to AZ, 2 more blocks, got their limited lifetime (as long as you own it) guarantee wires. They fit it runs like I stole it again. $42 It had an extra coil wire slightly shorter in it too.
Found out they also sell cut them yourself wire kit for $27 same guarantee.
I used dielectric grease on them this time. I think this may be a new "standard" for quality to get us to buy more. When I removed the rest of the wires two more connectors broke free. Oh yea the oil level was fine.
Old Apr 7, 2026 | 06:25 PM
Awesome. At least it was a relatively/easy fix.
Old Apr 7, 2026 | 07:26 PM
onemore94dak
Yea that was simple. i wonder how many other people have had wire troubles?
