Anyone try HHO?????
Old Aug 10, 2008 | 12:06 AM
  #101
IndyDurango's Avatar
IndyDurango
Less bitchin' and more test result posting. Some of us are interested in all of your experiments and not with the naysayers.
IndyD
Old Aug 10, 2008 | 03:58 PM
  #102
hydrashocker's Avatar
hydrashocker
I agree Indy. Lets get some more info on here.
Does anyone have any results yet they wish to post????
Old Aug 14, 2008 | 10:05 PM
  #103
jhyneman's Avatar
jhyneman
Simply I have been running HHO for the better part of 5 months. This is not a scam but if you follow the Water4gas books ditch the mason jar but follow the rest. If you want to see any results add a fuel heater, pcv enhanser and a EFIE module. There is a better set of plans for the generator on www.Mindstrain.com. These plans are FREE. I have been trying to perfect this and have seen aprox. a 5 miles per gallon increase and zero emissions.
Last edited by jhyneman; Aug 14, 2008 at 10:07 PM. Reason: wanted to add something
Old Aug 15, 2008 | 10:40 AM
  #104
DRO318's Avatar
DRO318
jhneman. were did you get you EFIE mod? How much did it cost you? DID the fuel heater actually help, because I would hate to start tinkering with the fuel line and it not be worth it.
I also have the pvc mod installed for quite some time now, has yous built up oil vapors aswell.
I have seen 5 mpg increase with the small mason jar, but I thought I'd get more with a bigger setup.
I thought the map sensor enhancer or EFIE mod would be the way to go. I still wonder about the IAC selonoid even though Hydra said it should be regulated. can you tune your EFIE mod?
Old Aug 17, 2008 | 04:59 AM
  #105
magicman32's Avatar
magicman32
Junior Member
I have the water4gas document in pdf and can email it to whoever wants it,
just pm or e-mail me and il send it to you
themagicman360@gmail.com
Last edited by magicman32; Aug 19, 2008 at 03:17 PM. Reason: adding e-mail address
Old Aug 24, 2008 | 01:13 PM
  #106
DRO318's Avatar
DRO318
Hey hydra have you got any response from that nomo gut on that chip HHO setup yet?
Old Sep 1, 2008 | 12:19 PM
  #107
jhyneman's Avatar
jhyneman
you can purchase the EFIE mod off of ebay. There are alot of good ones on there. They range from different prices of 50 to 150 dollars. I spent on a little more expensive one. It cost about $120. It comes with a 6 foot wiring harness and ports to digitaly tune it with a good multimeter. Don't mess with the Map sensor enhansor the computer will recognise it and recalibrate within 3 days.
The fuel heater worked and gave me the most efficient mileage gains. my mileage jumped 5 miles per gallon by installing it.
As for the bigger HHO setup, I installed a different style setup than the mason jar because I wan't happy with the HHO production. I designed a plate setup using 2 units of 6 plates of 2x6x.32 304 stainless steel. the plates are staggered using -+--+-. Hydrogen is produces off of the negative electrode and oxygen is produced off of the positive electrode. I wired each unit in series to drop the unit voltage because I was having alot of thermal runaway. I also designed a custom wiring harness for the generator. I pulled a power sourse from my cigarette lighter and ran the power to a relay. I then wired the relay to the genator because this unit will pull around 20A -40A depending on how much electrolite that you use. I also found that baking soda breaks down in about 3 weeks. I am planning to switch over to Soda ash. I have talked with some friends and they tell me they have even less residue build up in the container.
Old Sep 1, 2008 | 01:12 PM
  #108
DRO318's Avatar
DRO318
What hose do you the fuel heater hooked up to?
I thought you may have cot the EFIE mod of ebay. I did see some on there
Old Sep 1, 2008 | 09:08 PM
  #109
jhyneman's Avatar
jhyneman
I used the hose that goes from the radiator into the intake. It is the most accessable and has warm water as soon as the engine is warmed up.
Old Sep 2, 2008 | 08:28 AM
  #110
DRO318's Avatar
DRO318
Yes that does make sense. I am glad to see positive results from diff folks
