Driver seat issue
Old Jan 1, 2010 | 02:05 PM
  #41
hydrashocker's Avatar
hydrashocker
Originally Posted by rebelboy
sweet thank my seats always get loose from takin girl(s) out in the trails:-)
It's not the 4X4'ing that's braking "your" seats........LOL
Old Jan 1, 2010 | 08:40 PM
  #42
Kensai's Avatar
Kensai
Originally Posted by Gdschaf
well, how well do you think welding that will hold? I would like to get this fixed, no matter what the price, and be done with it, haha, the cheaper the better but I want the assurance of it not happening again, it's really annoying.
I would weld that piece back on the bracket and possible have a machine shop build another similar type plate and then weld/bolt that to the existing plate. This will re-inforce the original plate. Go to this link: http://www.craigcentral.com/durango/seat.asp That is the fix to address the piece that broke off on your driver's seat. The user posted the fix, welded the bracket to the rod and that was done.
I don't know if you can find that assembly piece from dealer to fix your issue. Basically it will be a entire seat replacement just to get that part.
Old Jan 1, 2010 | 09:25 PM
  #43
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
bs rebel you dont take any girls out on the trails with you, they would probably cry if they saw the way you treated your D
Old Jan 2, 2010 | 01:28 PM
  #44
skipig's Avatar
skipig
Thumbs up replace worn out shims
Nice write up Kensai. I had the same problem with my 98 and fixed it with some shims I fabricated from an old serpentine belt. The seat is rock steady now!
The seat removal on the 98 is the same
1. Unbolt the seat and remember to unhook the power and power the seat up to tallest setting so you have room to work.
2. Remove the bolt on the underside of the track. Yours was a standard bolt but mine had a star-head.
3. Remove the two star-head bolts on each track
TIP: Remove one side at a time! The threads on the track rod are different on each side!
4. Pull the rod out and measure the distance from the traveller to the end of the rod so you can put it back in the same location.
5. Unscrew the traveller from the threaded rod
6. Clean out the old bushing
7. Insert your washers or new bushings. I cut up an old serpentine belt for mine. Used a forstner bit to cut the a hole in the belt and then used some cutters and a grinder to properly size the new bushing. I even used the grinder to thin out the shim.
8. Thread the traveller back onto the rod.
9. Insert the assembly back into the track and bolt into place.
10. Do the other side.
11. Reinstall seat and enjoy your ride!
BTW, if anyone needs the whole dirvers side seat track assembly, I have one for sale for $50 + shipping with this fix in place. I bought a used track assembly (complete with controls) from an online junk yard thinking it would fix my problem but it had the issue as well. I fixed this on and the one in my truck so this one is a good replacment for someone who had other non-repairable seat track issues.
Mark
Attached Thumbnails  Driver seat issue-dsc06093.jpg    Driver seat issue-dsc06095.jpg    Driver seat issue-dsc06096.jpg
Old Jan 2, 2010 | 01:36 PM
  #45
skipig's Avatar
skipig
Mark
Old Jan 5, 2010 | 04:07 PM
  #46
tm985's Avatar
tm985
So in order to fix this it's going to require taking the seat off? I just got mine on Christmas and it's a lil loose and wanna fix it.
Old Jan 5, 2010 | 10:54 PM
  #47
hydrashocker
Get out your wrenches!
Old Jan 6, 2010 | 08:45 AM
  #48
shrpshtr325
THE ULTI-MOD
yup pull out the wrenches and get to work, make sure you got noowhere to go for a while in case you have problems
Old Jan 6, 2010 | 11:49 PM
  #49
hydrashocker
This isn't a bike with no seat......LMAO!
Old Jan 7, 2010 | 12:44 AM
  #50
Dans01Durango's Avatar
Dans01Durango
Yeah, the AZ is just a few blocks from my house so a milk crate will do for the moment!LOL!!
