Changing to a Airaid or FastMan TB HELP?
Old 07-22-2008, 04:54 PM
Momstruck's Avatar
Momstruck
Momstruck is offline
Default Changing to a Airaid or FastMan TB HELP?
[align=left]Hello Guys Its Me again
With another weird or dumb question? If I were to install a Fastman or Airaid TB do you have to change the black air box that sits on top of the motor and what with? Not the one that has the filter in it the other one that sits on top of the motor because now the bolts wont line up. HELP
Its on a 2000 D-4x4 4.7L Thanks Again
[/align]
Old 07-22-2008, 06:55 PM
nim81's Avatar
nim81
nim81 is offline
Default RE: Changing to a Airaid or FastMan TB HELP?
to get the best results switch to a cai (cold air intake) this will give you maximum air flow to go along with your new tb. and more room under the hood with all the stock airbox junk gone.
Old 07-24-2008, 09:33 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
A fastman TB will bolt right up because he uses the same TB just bored out. Stay away from Araid.
Old 07-25-2008, 02:53 PM
nim81's Avatar
nim81
nim81 is offline
whats wrong with airaid?i was talking about a cai not a tb
Old 07-25-2008, 11:10 PM
hydrashocker
The intake systems only bring in hot air so a custom intake CIA is by far better and the Fastman TB bolts up just as OEM because Dan uses OEMTB's as a core.
Your OEM air box will install on to your fastman TB.
Old 07-25-2008, 11:11 PM
hydrashocker
Just an FYI but a TB spacer does not work with an MPI motor so don't waste your bucks.
Old 07-25-2008, 11:33 PM
Momstruck's Avatar
Momstruck
What is a MPI motor? Would that be mine? Thanks
Old 07-25-2008, 11:38 PM
hydrashocker
Multi-Port Injection. And yes that is what you have.
Old 07-25-2008, 11:45 PM
Momstruck's Avatar
Momstruck
Thank you so much, you have helped me alot. I would of wasted my money. whew
Thank again
Old 07-25-2008, 11:59 PM
hydrashocker
That is why we are here.
Install a fastman TB then pipe your air in from outside the engine bay for a Cold Air Intake and install a K&N filter into the OEM air box. You will be HAPPY!
Quick Reply: Changing to a Airaid or FastMan TB HELP?
