turn signal light messed up
Old Aug 4, 2008 | 12:14 AM
M Shark's Avatar
M Shark
Default turn signal light messed up
For the past couple weeks I've noticed that when I signal to turn right, my hazard lights turn on. Although this was on and off, now it's everytime I turn the signal to the right.
I was wondering if this was just a simple signal light assembly replacement?
thanks in advance.
I have a 2002 Dodge Durango SXT.
Old Aug 4, 2008 | 09:24 AM
Duranged408's Avatar
Duranged408
Default RE: turn signal light messed up
ORIGINAL: M Shark
thanks in advance.
Old Aug 4, 2008 | 09:29 AM
Duranged408
I love writing long posts that give errors, i'll try again. Does your turn signals feel sloppy? iv'e never heard of that specific issue with hazzards, mostly headlight issues but it sucks that you've got to toss up $100 on a 50/50. I cant really give youa positive answer on that circuit but maybe someone else can help you better. I had a headlight issue and got stuck with a new multifunction switch due to a no return electrical dealership so if a 99 D's multifunction switch will work on your D i'll glady cut you a deal on a new unit that sits inmy basement
Old Aug 4, 2008 | 10:41 AM
hydrashocker's Avatar
hydrashocker
Could just be the ground. Look at the neg on the light.
Old Aug 4, 2008 | 10:59 PM
master tech's Avatar
master tech
Site Moderator & Tech
I had this problem about 8 months ago. the problem was the combo flasher. Turn the key and apply the left turn signal and find out were the combo flasher is and replace it.
Old Aug 5, 2008 | 08:05 PM
hydrashocker
It is square in the fuse panel on the drivers side inside removable panel.
Old Aug 18, 2008 | 03:59 AM
M Shark's Avatar
M Shark
How much did it cost to replace it? I'll check tomorrow morning when I get back from work (I'm an ER nurse working night shifts).
Old Aug 18, 2008 | 04:00 AM
M Shark's Avatar
M Shark
You wouldn't have the part# to it would you? Thanks anyway.
Old Aug 18, 2008 | 08:50 PM
Mean Green's Avatar
Mean Green
I have a flasher I would be willing to sell. I bought it when mine went bad only to find that whoever installed the aftermarket alarm routed a regular $2 flasher in. I got it for $45 from a dealer in NY and couldn't return it. Make me a reasonable offer and it's yours.
