How to change rear diff fluid?
Old Sep 1, 2008 | 08:35 AM
Kdmann64's Avatar
Kdmann64
New Member
Default How to change rear diff fluid?
Im trying to change the rear end gear oil in a 2000 durango 2wd, does not have limited slip. there is a rubber plug in the diff cover, i guess this is where i fill, how do i drain?
Old Sep 1, 2008 | 09:05 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
umm turn the truck upside down and thake the plug out
j/k
you could take the diff cover off but then you need a new gasket to replace the old one or you could just use a siphon through the fill hole and get as much out as possible that way
Old Sep 1, 2008 | 12:27 PM
hydrashocker's Avatar
hydrashocker
To me, I go to a persons shop I know and they siphon out the old and you want to install Fully Synthetic 80-90W.
Now turning the truck upside down and shaking it while the plug is out sounds great!
Old Sep 1, 2008 | 08:11 PM
n8ech's Avatar
n8ech
KD:
You can pull the cover, let it drain and clean the insides out with a dry non lint type towel.
Then, replace cover with RTV as a gasket. There is no gasket per se.
Second method is to pump the old stuff out through the inspection cover (rubber plug)
Then refill with a pump till it is just below the lip of the hole.
Should take around 1.75 quarts. Either Mobil 1 or Royal Purple synthetic is recommended.
If your fluid is OEM, you will be amazed at just how foul and dark it has become.
Don
Old Sep 1, 2008 | 08:53 PM
dhvaughan's Avatar
dhvaughan
if you're going to go to the trouble of doing it, do it right. remove the cover and drain it, then spray out the bottom with brake cleaner or a little gas (don't smoke) and get the sludge out of the bottom, especially around the magnet. use rtv as a gasket. don't overtighten.
here's pics. http://www.pavementsucks.com/tech/diff.php
Old Sep 2, 2008 | 12:57 AM
IndyDurango's Avatar
IndyDurango
It's 75W90 in the rear diff. I recommend Mobil1.
IndyDurango
Old Sep 13, 2008 | 11:58 PM
durango wb's Avatar
durango wb
has anyone tried a lucas oil fluid ,if so how was it
Old Sep 14, 2008 | 10:18 AM
DRO318's Avatar
DRO318
I run it every change Its the same nothing diff to feel
