Old Aug 5, 2015, 12:35 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: 4WD
Print Wikipost
Transfer Case Control Module Location, TCCM
Old Sep 24, 2011 | 03:56 AM
  #81
D0dgeDak's Avatar
D0dgeDak
Default Something New.
So as I was driving to work today I see that the lights on the selector switch all lit up and then went out. This happened three times. I have not checked the connection to the transfer case yet but will do so today. Just thought that the new developments might shed some light.
Old Oct 1, 2011 | 08:04 AM
  #82
skyward's Avatar
skyward
I need to replace my TCCM, as well. How do you release the electrical connectors? Do they have only the one lock tab (that can be seen) on the bottom side of the connector, or is there also a hidden one on the top side of the connector that needs to be squeezed? Thanks!
Old Oct 2, 2011 | 12:16 PM
  #83
cabindwellr's Avatar
cabindwellr
It's been awhile but I think think the release tab is only on one side. Most are. The conventional technique for removing sticky connectors is to oscillate the connector in the X and Y axis with 2 Newtons of tab pressure. The connector should release in the direction that propels the back of your hand into the sharpest object under the dash.
On a more serious note (not related to your post, Skyward): We're all happy and desperate for help when we consult the forum and are glad for the help the forum provides. When your crisis is resolved PLEASE take the time to post your results so others can learn from your experience. I'll also take this opportunity to thank Hydrashocker & Sharpstr325 for all their time, expertise, and patience helping the brother&sisterhood. Enuf said.
Old Oct 2, 2011 | 02:42 PM
  #84
skyward's Avatar
skyward
You were precisely correct, even to the hand propelling into the sharpest object!!
Further questions...Is it necessary to disconnect the battery negative cable when installing the replacement TCCM? Does the TCCM come 'online' without any programming?
Thanks!
Old Oct 2, 2011 | 09:09 PM
  #85
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
yes you should disconnect the battery whenever you do any electrical work
Old Oct 10, 2011 | 05:06 PM
  #86
skyward's Avatar
skyward
Default TCCM Replacement
Okay, I found a TCCM from a junkyard http://www.uneedapart.com/ ($40.00 including shipping) and installed it. My 2WD/4WD switch lights up and works as advertised!
I might point out that no one could offer me any compelling reason to disconnect the battery and I did not see it necessary to disconnect it for this, so I didn't.
Thanks, everyone, for your inputs and assistance!
Old Oct 10, 2011 | 10:18 PM
  #87
shrpshtr325
THE ULTI-MOD
the reasoning behind it is simple, whenever you are doing electrical work you run the risk of sparking and shorts, if you have a short or a surge (sparking is indicitive of a surge) you run a very high chance of damaging one of your electronic modules (usually the one you are working on)
Old Nov 4, 2011 | 09:45 AM
  #88
ICEDODGE's Avatar
ICEDODGE
I was looking for a reason why my dash is showing "Service 4wd" The 4Wd is working fine, but this light is always on. Was told that this could be the TCCM but my understanding is that if this module is broken, it will not shift the drive from 2Wd to 4Wd.
Is this correct? If so, is there another module that could cause this failure indication?
Old Nov 4, 2011 | 05:38 PM
  #89
hydrashocker's Avatar
hydrashocker
Most likely it is the module, but get under it and pull the harness off the T-case. Look for corrosion and unplug and plug in a few times to make sure it is getting a good connection.
Old Nov 5, 2011 | 01:36 PM
  #90
ICEDODGE's Avatar
ICEDODGE
Thank you hydrashocker. I will do that and keep you posted.
