99 Durango Ignition switch or linkage
Old Feb 23, 2009 | 03:33 PM
Beyond Hope's Avatar
Beyond Hope
Default 99 Durango Ignition switch or linkage
My neighbor just called with an issue on her Durango. The ignition switch shut truck off but wouldn't remove key or start in park. I physically tugged wheel R&L and nothing changed removing key until moved gear selector down to neutral and back into park. Key then removed but truck won't start in Park, only Neutral. My thoughts were a linkage problem but not knowing anything about this model my guess is the switch. Anyone else experience this problem? She's headed off to town shopping and hopefully won't be calling me stranded. LOL
Old Feb 23, 2009 | 06:24 PM
hydrashocker's Avatar
hydrashocker
Beyond Hope?????.......... LOL
Most likely the switch or the rod actuator. Removal of the switch is needed for further analysis.
Old Feb 24, 2009 | 12:10 PM
Mean Green's Avatar
Mean Green
Neutral safety switch I'm sure.
Old Apr 9, 2009 | 11:04 AM
Beyond Hope
Default correction to model year 1996
well it appears the problem persists. haven't heard from neighbor all this time thinking it was repaired. But here goes the problem, won't shift manually into park by no means, due to this she parks in neutral with Ebrake. Now when she asked me to take for a spin and check for a noise she hears I discovered the tranny slips from 2nd to drive quite bad. Someone has this buggy chipped out if that means anything and it revs quite high when shifting. Does this sound like trans failure or are there sensors one can scan for trouble codes?
Old Apr 9, 2009 | 11:22 AM
DRO318's Avatar
DRO318
you may need to have a new key made. It may just be cheaper. the guys are right though
Old Apr 9, 2009 | 03:57 PM
Duranged408's Avatar
Duranged408
Chipped out? If anything a performance pcm or superchips comp install.
Im leaning more towards a pressure solenoid in the tranny causing late shifts. But its always a safe bet to have the transmission filter replaced aswell bands tightened.
My truck for example of second high
Old Apr 9, 2009 | 09:45 PM
Beyond Hope
Thanks all for the input/feedback. Its beyond hope for me on this one, kinda like helping a really challenged person here so i advised her to take it to crappy tire and do us all a favor. LOL!!! Thanks again!
Old Apr 9, 2009 | 11:36 PM
hydrashocker
Band adjustment should help ya.
