Suspension maintenance question...
I've noticed that when going over speed bumps or pot holes I can hear the suspension squeak and make other annoying sounds.
What would I need to replace as preventive maintenance in the suspention to keep the D running strong? I currently have 105K miles on my 2002 Durango SXT. I've replaced the shocks with billsteins 2 years ago and that's about all the suspension work that has been done since I bought my truck back in 2004.
Thanks in advance!
Thanks in advance!
Don't replace. I doubt yours will be deteriorated when you look at them.
Get motorcycle chain wax, squirt it in as best you can and your done for months if not a couple of years.
They just squeak... a lot at times. I could get mine to by just getting in and out of the seat. No I do not weigh 500lbs either.
IndyDurango
IndyDurango
Trending Topics
I've tried all the temp solutions on my grommets. But none of them ever lived up more than a few months before you get that old bed box spring squeaking again. After a number of years, the rubber just deteriorates and hardens. You dont have that soft hard spongy feel anymore. It is just plain hard hard rubber! I guess living in DFW with extreme weather changes from dry to humid weather, etc just don't work well for hose grommets. The noise and irritation finally got to me and I went ahead and replaced them with OEM's. Too damn lazy to accurately measure the sway bar, etc to properly get the custom made polyeurathanes. I am on year 2 on the OEM grommets and still no noise. I did however pregreased around the areas where the grommets are fitted so I won't have to worry about the temp band aid fixes anymore.
Originally Posted by
Neo1130;1649643
Neo1130;1649643
495 is pretty damn close though!
If you replace the bushings, that should be scared (you need to take a look) and put some silicone lube on it should last ya. If anything while you have them out lube them and reinstall. Poly is the best way to go tho!
