engine failure questions
Old 05-30-2009, 03:08 PM
MetalDrgn's Avatar
MetalDrgn
MetalDrgn is offline
i'll let you know when I find out
  #32
Old 05-30-2009, 03:52 PM
MetalDrgn's Avatar
MetalDrgn
btw here are some pics of my $2000 durango
  #33
Old 05-30-2009, 11:45 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
Nice deal......!
  #34
Old 05-31-2009, 01:14 AM
IndyDurango's Avatar
IndyDurango
IndyDurango is offline
I'll buy it from you for $2100. You make a quick hundred bucks!
IndyD
  #35
Old 05-31-2009, 02:38 PM
MetalDrgn's Avatar
MetalDrgn
lol, I've already put over $600 into it just in gas, renting the car dolly, taxes and registration, and a few other things for it.
  #36
Old 05-31-2009, 09:11 PM
IndyDurango
Okay, you bent my arm... $2100 + your $600 = $2700.
IndyD
  #37
Old 05-31-2009, 11:00 PM
hydrashocker
^ lol ^
  #38
Old 06-01-2009, 05:49 PM
MetalDrgn's Avatar
MetalDrgn
rofl, that's ok I think I'll fix it first and have some fun with it over the summer and sell it for bluebook value once gas prices start to go down again in the winter. That is unless I like it a lot and decide to keep it longer
  #39
Old 06-01-2009, 09:04 PM
hydrashocker
Do a Tortion Lift (TS Lift) on it first!
  #40
Old 06-06-2009, 02:05 PM
MetalDrgn's Avatar
MetalDrgn
well I have an idea to try and further isolate the location of the problem. I will record the knocking sound and compare it to the idle speed to see if the knock is in the lower end, the cam, or timing chains. I have to put the valve cover back on and put a few things back together first. i'm glad I didn't start pulling the head!
if idle rpms are 650 that's 10.8Hz. If the knock is the same frequency, it's in the lower end. if it's around 5.4Hz, it should have something to do with the cam or a rocker arm. If it's lower than that I would suspect a timing chain. Hopefully this works. I'll let you know what I find.
Quick Reply: engine failure questions
