Dimensions of OEM Infinity amplifier.
Old May 8, 2009 | 03:50 PM
Kensai's Avatar
Kensai
Default Dimensions of OEM Infinity amplifier.
Does anyone have dimensions measurement for the OEM infinity amp located by the passenger kick panel???
Infinity finally came out with a compact Kappa series 4 channel amp that might be a good fit replacement to the OEM infinity amp. Here are the specs for the Infinity Kappa series 4 channel amp.
The dimensions for the Kappa 4 channel amp is 13" x 7-1/16" x 1-3/4"
http://www.infinitysystems.com/car/p...spx?prod=KAPPA FOUR&cat=AMP&ser=KAP&Language=ENG&Country=US&Regio n=USA
I would love to replace my oem infinity with this kappa 4 channel amp!
Old May 19, 2009 | 09:16 PM
schusterjo's Avatar
schusterjo
Best I can do for ya... I looked but could not find the dimensions.
POWER AMPLIFIER
DESCRIPTION
Models equipped with the Infinity premium
speaker package have a separate power amplifier
unit. This power amplifier is rated at 100 watts output.
The power amplifier unit is mounted to the right
cowl side inner panel under the passenger side end of
the instrument panel. The power amplifier unit can
be accessed for service by removing the trim from the
right cowl side inner panel.
The power amplifier unit should be checked if
there is no sound output noted from the speakers.
For diagnosis of the power amplifier, refer to
Speaker in the Diagnosis and Testing section of this
group. The power amplifier cannot be repaired or
adjusted and, if faulty or damaged, the unit must be
replaced.
Old May 19, 2009 | 09:49 PM
Kensai's Avatar
Kensai
Ah shucks. Oh well, I will have to manually measure it then. I am almost sure the rear channel output is giving out. It is just not anywhere near loud compared to the fronts.
Old May 20, 2009 | 10:32 AM
Duranged408's Avatar
Duranged408
Gimmie a few mins and i'll pull mine out and measure.. If ya want you can have it...
* i removed mine in favor to do a stand-alone system. After market deck- rca's- to aftermarket amp in back seat- all new thicker speaker wire- through door harness to aftermarket speakers
Old May 20, 2009 | 10:39 AM
Duranged408
Going per post photo
Without the top brackets, size is 8 1/4 tall 6" wide and 1 1/2" thick. With brackets it would be 11" tall.
99 dur slt
amp labeled as follows
Chrysler Corp. 56043029AC 36670 Infinity ( Barcode 36651770)
Old May 20, 2009 | 03:36 PM
Kensai's Avatar
Kensai
Damn, that means the infinity amp is still too big! 13 inches in height and slightly wider too. I guess the OEM's don't want us to use these spaces with aftermarket gear!
Very hard to find a aftermarket 4 channel amp with these minimal dimensions!!!!
Old Feb 14, 2010 | 09:25 PM
superjoey01's Avatar
superjoey01
Default durango amp wiring dig and location
hi my name is Joey i just bought this 1999 durango. i was going to add a amp to my durango but i have to find the amp outputs to hook up a converter to run rca. i also had these jvc speakers there are 6 1/2 but they dont fit i was wondering what can i do about that too, anybody have some idea thank you
Old Feb 15, 2010 | 07:04 AM
Duranged408
If your installing subs and have a factory HU you will need to tie the amp into a speaker wire via a 2 channel converter as you already know. Just tie into a line before it reaches the door. As for the 6.5" i dont see an issue using the old mounts, but if so you can readily get mounts per application at places such as crutch.
Old Feb 27, 2010 | 09:49 AM
Kensai's Avatar
Kensai
if anyone is interested in keeping a clean OEM look. Blaupunkt is the only decent 4 channel amp that is a perfect replacement for the OEM amp and will fit in the original location behind the passenger side kick panel. Some good user reviews that bought this amp is for a Dakota! So it should work for the Durangos as well!
http://www.amazon.com/Blaupunkt-THA-.../dp/B000VOEFJC
Now I gotta save up for this amp.
Old Feb 27, 2010 | 11:02 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
good find kensai, i guess im gonna have to keep that in mind when mine finally gives up on life
