All Electric Fan Swap + Much More
Old Jun 3, 2009 | 02:36 AM
IndyDurango's Avatar
IndyDurango
Default All Electric Fan Swap + Much More
I'm going to remove the clutch fan, stocker electric fan, old radiator, shroud, coolant overflow and windshield washer tank this weekend. Also re-running the grounds to the battery with a few mods there too. I have all new parts going back in and replacement concepts for the tanks and shroud that'll stand in for the stocker stuff.
I have a brand new Taraus fan, the Flexalite VSC controller that'll be used to keep the D cool automatically.
QUESTIONS:
- Any nice photos of shroud tank replacements that you guys have done?
- I plan on grabbing 'key on power' from the fuel pump relay under the hood. Comments suggestions there?
- With the oil and transmission coolers, any predicted issues on uncoupling them from the stocker old radiator while the replacement goes in? I hope to just pull them out of the way but not sure on the bracket connectivity.
- Did you guys pull off the crossmember brace while doing the fan only swaps? I think it has to come off for the radiator swap.
- Any other advise, gotchas-to-look out for?
I'm hoping to be down just Saturday via a 5-10 hour session depending on what all it takes to complete the mods. I'll be over the road testing out the setup directly via trial-by-fire with a 650 mile round tripper to Northern Ohio on Monday, followed by the next weekend a 2500 mile round trip to Florida and then two weeks later a 1300 mile round trip to Carlisle. With daily driving tossed in there, I don't have the luxury of it not working the first time out.
Thanks a million for all the advice, and assistance in advance.
IndyDurango
Old Jun 3, 2009 | 09:15 AM
Dans01Durango's Avatar
Dans01Durango
Good luck Indy! Please keep us posted with pics and write-ups.
Old Jun 3, 2009 | 07:02 PM
Kensai's Avatar
Kensai
+2 on write up and lots of pics!
Old Jun 3, 2009 | 10:50 PM
hydrashocker's Avatar
hydrashocker
As for the coolers I see no issue.
The fan can be removed easly without removing the shroud on mine. Yours is different than mine!
You can buy a fan with the shroud built on to install perfectly. Just remove yours and bolt on.
I would pull from the PDC red wire in direct attachment and install a hard wire fuse as seen in here on the left. Don't look at the paint circles because they were for a different write up.
I would do the swap when you get back and have more time on your hands.
Old Jun 4, 2009 | 11:04 AM
lv360ram's Avatar
lv360ram
I like the operation of the VSC to reduce startup surge and noise. I just bought a fan and I am going to order the VSC.
Old Jun 9, 2009 | 12:04 PM
Dans01Durango
So I'll only need the VSC? No need for a relay? Please advise. Thanks!
Old Jun 9, 2009 | 12:57 PM
hydrashocker
We need write up's with pictures and part #'s
Old Jun 9, 2009 | 10:48 PM
IndyDurango
Done. Works great. Looks good. I'll get a write up done soon.
IndyD
Old Jun 9, 2009 | 11:08 PM
Dans01Durango
Congrats Indy! One question, did you use a relay for the VSC?
Old Jun 9, 2009 | 11:19 PM
IndyDurango
No. LOL. The VSC has all the relays it needs built into itself. One and done my friend.
IndyD
