CV Shaft
Old Oct 30, 2009 | 06:14 PM
Dman98's Avatar
Dman98
Default CV Shaft
Replaced due to leaking outer boot.
Attached Thumbnails CV Shaft-pa290060.jpg   CV Shaft-pa290067.jpg   CV Shaft-pa290073.jpg
Old Oct 10, 2010 | 10:02 PM
Dman98's Avatar
Dman98
While doing some trans work I noticed the left front axle boot split and leaking grease. I caught it early, because there wasn't much grease on the wheel well or suspension. Some coincidence as I just change the axle on this side for the same reason almost a year ago.
As usual, some pics;
Looking at the pics, it appears to be the split at the same location.
Old Oct 11, 2010 | 07:11 AM
Dman98's Avatar
Dman98
For the people who are having problems opening the pics from the first replacement on 10/30/09, here ya go;
All repaired
Old Oct 11, 2010 | 08:25 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
sounds to me like somethings wrong there, you shouldnt be going through cv boots yearly like that . . .
Old Oct 11, 2010 | 10:18 AM
Dman98's Avatar
Dman98
What do you think would make the boot split like that, it's not touching anything.
Old Oct 11, 2010 | 10:49 AM
shrpshtr325
THE ULTI-MOD
its not touching anything while its up on the jack, but put the truck on the ground and look, if its not touching anything than you got a faulty boot on the first axle
Old Oct 11, 2010 | 01:44 PM
Dman98's Avatar
Dman98
That was the first thing I checked, I keep an eye on this one.
Old Oct 11, 2010 | 08:46 PM
shrpshtr325
THE ULTI-MOD
thats really weird idk what to tell you to look at specifically except that im not 100% sure your brake lines are run correctly
Old Oct 11, 2010 | 11:31 PM
hydrashocker's Avatar
hydrashocker
Watch the shock to ensure it is not touching. Other than that I think it was just a crappy boot.
Old Oct 12, 2010 | 12:21 PM
SumAmerican's Avatar
SumAmerican
look at this picture again.. Name:  PA290060.jpg
notice the lack of grease build up on the brake line right after the first S curve.. At least wrap that portion in some tape.. could be nothing but worth babying a bit..
+1 Shrp
