Trans relearn and sludge
Old Dec 17, 2009 | 10:24 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
switching to synthetic will increase the chance of oil leaks, but you should still be able to switch if you would like to, in the long run your engine will benefit from the switch
Old Dec 17, 2009 | 10:37 PM
mrwilliwizard's Avatar
mrwilliwizard
alright cool thanks
Old Dec 18, 2009 | 02:25 PM
smokersteve's Avatar
smokersteve
Yes I used +4. And replaced both filters.
I have not looked in side the eng but when I looked at the cap it was covered in yellow foam and another time black gook.
The PCV was changed and sparks are new.
Thanks for the help guys
Old Dec 18, 2009 | 03:37 PM
shrpshtr325
THE ULTI-MOD
that is normal for the 4.7 and IS NOT SLUDGE, its just moisture that "boils" out of the oil and builds up there (the highest point inside the engine) my truck gets that every winter, just wipe it out before you add more oil
Old Dec 18, 2009 | 11:34 PM
smokersteve
Ok thanks
Why does this effect happen?
Thanks for the help
Old Dec 19, 2009 | 12:24 AM
IndyDurango's Avatar
IndyDurango
It happens because air is mixing with the water. Many in the know call it "snot". There is a Service TSB on how to fix/prevent it. With that said... IT IS NOT SLUDGE!
IndyDurango
Old Dec 21, 2009 | 12:11 AM
smokersteve
Thanks!
Old Dec 21, 2009 | 12:32 AM
IndyDurango
Here are a few snot photos of the snot (NOTE: not Sludge!) problem on the earlier 4.7s and the TSB to fix it.
Service Bulletin Number: 090100A
CUSTOMER MAY COMPLAIN OF AN OIL EMULSION ACCUMULATION INSIDE THE ENGINE OIL FILL HOUSING
Need to install the following 2 parts
53032126AA Baffle, Oil Fill Housing
53032389AD Cap, Oil Fill Housing
Recommend replacement of the PCV valve as well.
Happy to help,
IndyDurango
Old Dec 21, 2009 | 06:42 PM
smokersteve
I replaced my pcv. Where do you think I can get the 53032126AA Baffle, Oil Fill Housing
Thanks
Old Dec 21, 2009 | 09:58 PM
shrpshtr325
THE ULTI-MOD
go to the dealer, but print out the tsb before you go and take it with you, then you will have the part numbers ect
