Performance Mods 02 SXT.....
Old 02-21-2010, 02:54 PM
myshoeisonfire's Avatar
myshoeisonfire
myshoeisonfire is offline
Question Performance Mods 02 SXT.....
got an 02 SXT with 4.7 2.5" exhaust with 40 series flowmaster (no cat)
ive looked around the forum a bit...
looking for some mods... like larger fuel injectors....
are the stock ones the standard 22# injectors? usually ive had luck on other brands of V8's going with 24# ones...
also, I heard rumors of a new intake? mind has the large plastic one.... any links, or thought as to which ones are best?
I am in an area where emissions / cat converters do not matter.
most people seem to want POWER, AND MPG...I, however, Do not care about MPG
my friend has a jeep with this same motor in it, and it REALLY RIPS!! I know the jeeps are a bit lighter.. but it has LOTS of power!... did they de-tune these engines for use in the Durango?
thanks in advance!
-Dan
Old 02-22-2010, 01:56 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
1. The regular injectors will give you enough fuel even in porting heads. I don't think you need bigger.
2. I know of camming the motor or P&Ping the heads, exhaust 3", Ram Air CIA, could run headers if built right, but there really isn't much to do to that motor.
3. The Jeep is probably re-geared with lower gears giving you more "Power". Yours probably has taller gears like 3:55.1 and he's might be 4:11.1's.
I know there is a package you can get for the 4.7L but I can't remember the name off the top of my head. One of the 4.7L guys should know of it?
Old 02-23-2010, 09:46 AM
Dans01Durango's Avatar
Dans01Durango
Dans01Durango is offline
I would like to say, great name Dan!
You can do a homebrew CAI and alot more mods using this link, https://dodgeforum.com/forum/1st-gen...wers-faqs.html. HTH.
Old 02-23-2010, 10:34 AM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
you could get a bigger throttle body from dan the fastman, im pretty sure there are cams out there, not 100% sure as i dont have any money to mod mine
Old 02-23-2010, 11:15 PM
hydrashocker
It's ok, your just cheap!.....
Old 02-23-2010, 11:28 PM
shrpshtr325
THE ULTI-MOD
lol, cheap and broke are two totally different things hydra . . .
. . . . ok maybe not
Old 02-24-2010, 01:13 AM
Dans01Durango
I think he's just cheap. I seem to recall someone saying their driveway can fit 12 cars... Or was I mistaken?
Old 02-25-2010, 12:20 AM
myshoeisonfire
is what im hearing correct??!?.. that all the power has already been designed out of this engine? usually there's stuff you can do!! its not a freakin honda after all! lol V8's RARLEY have ALL the power from the factory :^)
im not opposed to swapping out the cams, also on these gas motors, is there any benefit to running a modded/chip / programmer?
Do the 4.7's deal with a supercharger ok? or should i look for another motor?
how about the actual plastic main intake manifold..? any benefit on changing that out?
***** GM refrence alert***
Usually on the chevy TPI 5.7L I swap out to 14# injectors (12# come stock)and custom write a program chip for the computer.... the computer on GM cars allows you to do this.... never played around with dodge before...
the 2002 Durango works well for me - and I have no intention of switching to a different vehicle, or year.. I do government work, and all the equipment I have is specially designed for this year / model - that being said... I am not worried about meeting emissions, or spending some money!!
I have been toying with the idea of swapping in a Durmax - (950HP sounds good to me!)
thanks for any thoughts!!!!
-Dan
Old 02-25-2010, 09:45 AM
gr8scott72's Avatar
gr8scott72
gr8scott72 is offline
-Dan
4.56:1 gears and you'll be smiling from ear to ear.
Old 02-26-2010, 10:26 PM
hydrashocker
-Dan
There isn't much avalibe for the 4.7L so I don't know what to tell ya.
As for you Duramax idea, First you need to get your numbers correct....AKA...."950HP".......ROTFLMFAO!
Quick Reply: Performance Mods 02 SXT.....
