Cruise control 1998 5.2L Durango
Old Mar 4, 2010 | 09:52 PM
tommyt13's Avatar
tommyt13
Default Cruise control 1998 5.2L Durango
My cruise control will not engage, and it the vehicle had this issue when purchased. The cruise light will turn on and stay on, but it will never engage. I would appreciate any suggestions.
Old Mar 4, 2010 | 10:27 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
check the connections leading into the cruise servo, i dont have a service manual for your truck so im not sure where it is, im not sure if there is a vacum line on the cruise system for these trucks or not, but check for cracked or open vacum lines too
btw, i hope you did not buy the truck new
Old Mar 4, 2010 | 11:44 PM
hydrashocker's Avatar
hydrashocker
+1 Sharps!
Old Mar 6, 2010 | 04:10 PM
tommyt13's Avatar
tommyt13
Is the cruise servo the same as the speed servo? If so I checked the vacuum from the engine to the speed servo and it was fine. I then removed the cowl plenum to check the vacuum reservoir and one way check valve. Both items check fine. Did I just narrow it down to something in the brakes?
Old Mar 6, 2010 | 09:37 PM
shrpshtr325
THE ULTI-MOD
it COULD be a bad break light switch, causing the cruise to kick off immediately, but i would expect you to have brake lights on all the time if that were the case
Old Mar 6, 2010 | 11:24 PM
hydrashocker
I would replace the $10 dollar brake switch.
Old Mar 14, 2010 | 12:10 PM
tommyt13's Avatar
tommyt13
Thanks for the help guys, the $16 brake switch from NAPA did the job.
Old Mar 15, 2010 | 03:39 PM
hydrashocker
Thanks for the update!
