The Correct Way To Purge Any Transmission
Old Jun 13, 2010 | 09:25 AM
  #21
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
if you have the 44 or 46 it is just a band adjustment, tighten the bolt to a certain point, hydra has the numbers for you
Old Jun 13, 2010 | 10:03 AM
  #22
San Antone RR's Avatar
San Antone RR
Stock 5.2, so I imagine it is a 44 like was said earlier. I found the thread about the solenoid replacement and there was a link to the band adjustment.
I have never done tranny work, so this will be new ground for me. Going to get the kit, fluid and the solenoid and OD valve tomorrow. I doubt if anyone will have it in stock and be open on a Sunday. Also need a in/lb torque wrench.
Old Jan 18, 2012 | 09:52 PM
  #23
kingoftow's Avatar
kingoftow
Default Tranny-purge info...
You see...that's why I'm glad I subscribed to this forum, you folks are constantly dropping good usable tech on us. This is especially appreciated by veteren home shop mechanics like me who do all of our own work on our vehicles, thanks much...kingoftow
Old Jan 19, 2012 | 01:30 AM
  #24
otgarzà's Avatar
otgarzà
One of the best posts ive seen. Read this awhile back and looking forward to doing this sometime soon when i get my new trans pan. Thanks for the amazing write up.
Old Nov 1, 2013 | 02:06 PM
  #25
lragan's Avatar
lragan
45AutoPete, --Thanks for the careful post of purge instructions.
Anyone who knows:
I started getting a P0740 code on the 45RFE in my '02 Durango shortly after an oil change shop changed out my filter -- and, I suspect now, added the wrong fluid. Only thing I don't understand is how to know when to stop the purge process. Will the fluid suddenly change color? Quit when I have collected 12 quarts in the discharge bucket?
Last edited by lragan; Nov 2, 2013 at 05:15 PM. Reason: Clarify my question with additional detail.
Old Nov 2, 2013 | 11:06 PM
  #26
Old_School's Avatar
Old_School
Anyone who knows:
I would assume that since its pretty fresh fluid that chances are its not very dirty yet to notice a change in color when the new stuff comes out.. If it where me, i would just run 13 quarts though it and hope you got it all out without any neg results.
P0740 on the 45RFE is a torque converter clutch control circuit fault. That's usually thrown when there is a bad converter clutch solenoid. Being that you suspect the wrong fluid added it could have killed it or jammed it up some how
Old Nov 3, 2013 | 09:28 AM
  #27
lragan's Avatar
lragan
Smile Thanks for your reply Old_School
I am working through the checklist of possible causes one by one, starting, since I am basically lazy, with the easiest to accomplish ---
I found a rather long discourse here:
http://repairpal.com/OBD-II-Code-P0740
So, I will update progress here for the amusement of the more experienced...
Old Nov 4, 2013 | 08:41 AM
  #28
davidcareyf's Avatar
davidcareyf
5. Before starting engine, remove return line from radiator and install fitting with a hose on it. Put that into a pan to catch the trans. fluid. I use an old gallon gas can as that is a
Okay, just to be clear.
You are saying to remove the return line from the radiator, wedge a hose on it, not put some kind of 'T' fitting on the line. Run the hose in a catch can and replace the fluid as it is filling the catch can, while the engine is running. I take it the engine is in neutral? When the fluid coming out starts to look fresh, then stop the engine I assume, and reinstall the return line, check for leaks. Does this sound right?
While the engine is running, do you place it into gear, drive or reverse?
Thanks
David
Old Nov 4, 2013 | 04:05 PM
  #29
Old_School's Avatar
Old_School
Thanks
David
pretty much, just make sure NOT to run it dry....
Dodge transmissions do not flow fluid while they are in park so you would have to put it in a gear to get fluid.. i would use neutral.
