Old Aug 6, 2015, 11:41 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
Common A/C issues: problems and solutions
Old Sep 19, 2016 | 04:25 PM
  #261
JRobinson773's Avatar
JRobinson773
Ok thank you. Any idea on my other issue?
Old Sep 19, 2016 | 04:53 PM
  #262
JRobinson773
Originally Posted by that_guy
This is not necessarily true. There is a pressure relief valve that has most likely opened because the system is overcharged. The system needs to be evacuated, have a vacuum pulled on it, and be refilled with the correct amount of refrigerant (assuming the vacuum holds).
Any idea on the reason why it's blowing cold in the rear & hot in the front? I keep seeing things about expansion valves then stuff about the blend doors.
Old Sep 19, 2016 | 07:24 PM
  #263
that_guy's Avatar
that_guy
Could be either honestly. The front and rear have separate expansion valves and obviously blend doors. I have no experience with the electric blend doors on the 01+ trucks.
If you do end up changing the expansion valve though, be very careful with removing the bolts that hold the expansion valve to the evaporator. Steel bolts into aluminum makes for a pain in the ***. I ended up having to machine my new expansion valve and make a nut out of a larger Allen cap screw to avoid yanking the evaporator out of the dash when one of my bolts sheared off.
Old Sep 20, 2016 | 08:41 AM
  #264
JRobinson773
Ok, thank you. I really appreciate it. I will work on it this weekend.
Old Oct 30, 2016 | 08:03 PM
  #265
vox87's Avatar
vox87
Started hearing a rattling coming from my AC compressor. Noise sounds like a spray can being shaken up. Sort of loud, almost sounds like its coming from the back side (right/driver side) of the compressor.
1. Noise doesn't start instantly. Takes about a minute or two after starting up with the AC on.
2. Noise doesn't happen, when AC is turned off.
3. Air still blows cold.
Not sure, if this is the AC clutch since it sounds like its in the compressor vs. the pulley/clutch (bearings).
Thanks for any help on this.
Old Oct 30, 2016 | 09:10 PM
  #266
that_guy's Avatar
that_guy
That's pretty strange. The pulley turns all the time, even with the a/c off. The clutch shouldn't make any noises like that either.
Old Nov 1, 2016 | 12:56 PM
  #267
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
kind of sounds like its something in the compressor to me, sorry i cant be more specific.
Old Nov 11, 2016 | 01:26 PM
  #268
vox87's Avatar
vox87
Sorry for the delay in following up. Thought a video would be better than further descriptions. To me it does sound like its the compressor or maybe its the clutch, but I wanted to make sure.
Video (sorry for the wind) with the AC button OFF, air on high...no noise.
Video (sorry for the wind) with the AC button ON, air on high.
@ 0:09 - clutch disengages, noise stops
@ 1:29 - clutch disengages, noise stops
Old Nov 11, 2016 | 08:55 PM
  #269
that_guy's Avatar
that_guy
That's got to be something internal to the compressor. I'd stop using the a/c before it fails completely.
Chances are you're going to be replacing the compressor. The complication is that we have no idea what exactly on the inside is making that noise and how far along it is, so we kind of have to assume the worst here. If something in there is throwing metal filings around the a/c system and you just put a new compressor on, it's probably going to take it out in short order. At a minimum you're going to be replacing the filter/dryer (you should any time the a/c is opened) and doing a flush of the rest of the system. You'll also see recommendations to replace the condenser (parallel flow compressors are next to impossible to completely flush) and the expansion valve(s) as well.
Most compressor manufacturers won't honor a warranty on a new compressor without some evidence of these things being done.
Old Nov 12, 2016 | 06:46 PM
  #270
ole silver 03's Avatar
ole silver 03
x2 on what that_Guy Said .....its time . Don
